Subject Topic: Light will not respond to linked groups Post ReplyPost New Topic
tbeckman
Posted: December 17 2011 at 18:44 | IP Logged Quote tbeckman
I have one insteon light that will response to ALL ON/OFF, it will respond if I individually toggle it from power home, but it will not respond if it is a part of a linked group. All the rest of the lights in the group respond but it. Anyone had any experience like this? Thanks.
Edited by tbeckman - December 17 2011 at 18:44
Back to Top View tbeckman's Profile Search for other posts by tbeckman
Posted: December 18 2011 at 08:33 | IP Logged Quote grif091
What type of Insteon device is not responding? What type is the Controller?
The All ON/OFF uses a special Insteon Group number so it does not have the same dependency on link record content as a specific Group command.
Controlling from PH (toggle On/Off) is not using link records at all.
It sounds like a link record problem. What values are defined in the Group and Button columns for the link between the Controller and Responder that is not working?
