Frank002 Newbie
Posted: December 02 2012 at 12:33 | IP Logged
I just installed PowerHome2 with the hope of transitioning from ISY as my controller. I use a combination of X10 and Insteon products. I am connecting through a PLM 2412U. I have not yet installed any macros, triggers, or other special actions. When the PowerHome2 program is running, an x10 signal to switch on certain X10 switches, e.g., A4, will register on the PowerHome2 log as an incoming X10 signal and will turn on the appropriate switch. Within a second or two, however, the switch will turn back off, though nothing is logged within PowerHome2. The problem goes away if I exit the running PowerHome2 program.
What can be done about this?
Posted: December 02 2012 at 13:04 | IP Logged
Are you looking at the Insteon Raw Log under Insteon Explorer?
If anything is coming out of PH it will be in the Insteon Raw Log.
Frank002 Newbie
Posted: December 02 2012 at 13:51 | IP Logged
Lee, thanks.
I will start looking there. And, of course, what was previously 100% reproducible is not now happening.
Ed
Posted: December 02 2012 at 14:07 | IP Logged
Ain't that always the way.
Was/is the ISY still operational? Wondering if it was responding to the X10 traffic.
Frank002 Newbie
Posted: December 02 2012 at 20:56 | IP Logged
I unplug the ISY when testing the PH.
