         traviskleckner Senior Member
           | Posted: December 05 2012 at 12:00 | IP Logged
I've got a LampLinc Dual-Band (2457D2) that seems to be
 going crazy.  There where hundreds of links in it's
 responders list in PH and are all ID: [ID NOT FOUND] and
 the address is FF.FF.FF.  I deleted them and it went
 through and purged the list, but if I leave "enable
 pending" checked it seems to constantly have a record
 like "SCAN LINK: record xx, Device ABC" (where xx keeps
 going up and abc is the device name).  Each time it ads
 another bogus link.
 But really, the primary problem is that it doesn't seem
 to allow any linking.  I added links between that 2457D2
 and a SwitchLinc and a couple keypads.  It shows in PH
 that the links are created and verified but they don't
 work.  The LampLinc just does nothing.  I can manually
 link the LampLinc.
 Just to muddy the waters, I also recently both updated to
 Power-Home 2.1.4 + I2CS patch.  For what it's worth, I
 had "link scan" and "Allow Link Spidering" on becuase I
 thought that then it might detect the manual link I had
 done between that LampLinc and new RemoteLinc 2.
           | Posted: December 05 2012 at 12:29 | IP Logged
Travis,
 The first thing I would do is a factory reset on your Lamplinc.  You should be able to accomplish this by unplugging the lamplinc, press and hold the "set" button, plug it in while still holding the "set" button for about 15 seconds.  This should completely wipe the links (it sounds as if the link database was corrupt).
 Next, let PowerHome scan the links (it shouldnt find any).  Before actually scanning the links, I would probably clear the PH link database for the LampLinc device.  You can do this from Insteon Explorer on the "Links" tab.  Make the Lamplinc the current device and then click the headers in both the "Controllers" and "Responders" for the LampLinc device.  This should highlight all the rows.  Now instead of dragging/dropping the links, press the "Remove" button.  You'll get a popup message, just press Yes.  Save your changes.  This process actually just wipes the links from the PH database without trying to actually remove them from the device (the factory reset would have done that).
 Lets see where that gets us.
           | Posted: December 05 2012 at 13:13 | IP Logged
Thanks for the fast reply!
 I reset the device and removed the links like you said.
 I reinitialized PH just for good measure.  After the
 reinit, the Pending Operations now shows the same "SCAN
 LINK:  Record X, Device ABC" but X has restarted at 1.
 Each time it runs it creates a new record as a responder
 on that device, with a button of -X
 Log looks like this:
 TX  sendinsteonraw=00 00 00 1A DD 06 05 2B FB
 RX  EVENTRAW=03
 RX  SENDINSTEON=00 00 00 1A DD 06 05 2B FB
 RX  SENDINSTEONRAW=TRUE
 RX  EVENTRAW=03
 RX  EVENTRAW=04
 RX  sendinsteonraw=04 1A DD 06 09 46 9A A5 2B FF
 RX  INSTEON NAK=1A DD 06
 (Almost certainly unrelated, but Echo Raw Log to File
 indicates that it can't open a blank file)
           | Posted: December 05 2012 at 13:14 | IP Logged
Maybe related, but under reports that device shows a NAK
 bar that's like 99% where everything else has a ACK bar
 that's 99%.
           | Posted: December 05 2012 at 13:45 | IP Logged
Travis,
 The SCAN LINK: Record 1, XXX is a normal display for scanning the links.  What should happen is that it should start at 1 after scanning the first link entry and seeing no records exist, then its finished and no links will appear in the database.  But since you're getting a NAK (more on this in a minute), it will constantly repeat this command.
 Based on the log the returned cmd2 being FF, it appears that this is an I2CS device.  My guess is that you originally added this Lamplinc device to PowerHome before you applied the I2CS patch and now PowerHome cant detect that its an I2CS device.  I need to come up with a cleaner way to reset this condition but the easiest way to fix it right now is to delete the device from PH (Insteon Explorer->Devices tab) and then Save your changes (all IE tabs).  Then add the LampLinc back and leave the type as AutoDetect.  Make sure that Enable Pending, Status Scan, and Link Scan are all checked.  Save the newly added device and PowerHome should work out the I2CS and make all the appropriate entries and then properly scan the links.
 Let me know.
           | Posted: December 05 2012 at 14:15 | IP Logged
 I'm starting to wonder if this device is just whacked.  I
 did all the steps above.  When I when to add it (I used
 the  Auto Discovery as I always do) it discovered 2 new
 devices:  (and the , isn't a typo)
 06,01.0E
 02.1A.DD
 But what's weird is the new device is 1A.DD.06 (right
 from the back of it.)
 So I deleted one device in PH and then fixed the address
 of the remaining to be correct.  Set to * Autodetect Type
 * and let it fly.  Returned with * Type Not Found *.
 Any thoughts?
           | Posted: December 05 2012 at 15:29 | IP Logged
Hmmm...it sounds like it may even be the PLM.  You didnt happen to have the "Echo Raw Log to File" setup did you?  If not...assuming its duplicatable...it would be great if you could repeat the above steps so I can track whats going on.  I would then be able to determine if its the PLM, the device, or even PowerHome that is tripping up.
 If you havent already setup the raw log to file option, you'll need to go into PowerHome Explorer under Setup->Controllers and click the settings button for you PLM.  There you will define a full path and filename for the log file.  After doing that, you'll need to reinit or restart PH.  Then you can just place a check in the Echo Raw Log box and it'll save all the Insteon transmissions so I can see exactly whats going on.
           | Posted: December 05 2012 at 15:41 | IP Logged
I tried setting the log file under controllers but it's
 got a "5" in there right now and no matter what I change
 it to it just goes back to "5".  Is there another way to
 update?
 Hmmmm....I'm wondering if the problem is that my PLC.  I
 looked at my Smarthome orders to figure out the exact
 device I have and noted that on the product page for the
 2414U it says "PowerLinc Controller no longer works with
 any INSTEON devices sold after March 2012."
 I'm thinking the problem is my PLC is from 2007 and new
 devices might not like it.  I do have another LampLinc
 that's actually from a March 2012 order and it works fine
 but maybe my PLC isn't happy with the new stuff.
 That said is the 2413U the preferred device these days?
           | Posted: December 05 2012 at 16:20 | IP Logged
Travis,
 To fix the log error, you would need to delete the entry for the controller, save, and recreate the entry.  The problem would have occurred during an upgrade in PH versions and it didnt successfully add the extra column for the logfile name.  Dropping the controller entry completely and recreating it will solve that problem.  Just make sure that you recreate it the same (probably write it down or take a screenshot).
 That said, I thought you had a PLM.  If you've got a PLC then you are definitely going to have problems with I2CS devices...simply they won't work.  You can manually create a link to the PLC from the Lamplinc and you'll be able to control it from PowerHome but you won't be able to do any type of software linking, etc.  You would basically need to mark the LL as disabled so PH doesnt attempt any of the background communications with it.  This would buy you some time but you would need to upgrade to a PLM in order to get full support back.
 The 2413U is a fine device.  I prefer serial over USB but my favorite device at the moment is actually the 2412N (SmartLinc) which currently on sale for $99.99.  This is an IP device meaning no USB or serial, just plug it into your home network.
 Sorry for the bad news.
           | Posted: December 05 2012 at 16:30 | IP Logged
I hardly consider that bad news...that PLC has been around
 for 5 years and is intermittently cranky.  I ordered a
 2421N from Amazon so we'll see if that fixes the problem.
 Anything special I need to know about moving over to the
 new one?
           | Posted: December 05 2012 at 20:19 | IP Logged
If you mean 2412N instead of 2421N then the 2412N is not exactly like the PLM. You best go to this post for information.
  http://www.power-home.com/forum/forum_posts.asp?TID=3057&KW= smartlinc
 And if it doesn't work you may have to go to the Drivers folder in Powerhome and install the serial drivers. When it works it looks just like a PLM and you can run it from anywhere.
           | Posted: December 06 2012 at 14:21 | IP Logged
Okay, the 2412N is up and running.  All previous things
 seem to be working (thank god for the SWAP ID function).
 When I installed it PH didn't seem to recognize it's
 IEngine, and wasn't creating links.  I changed it to I2
 and it seems to have built all the links on it.
 The 2457D2 is better but still doesn't seem to be able to
 make links.  I can control it from the device manager
 without problem.  It shows 100% communication.
 It's R1.9 and then under that 2912.  When I
 AutoDiscovered it it at least showed up correctly.  It
 was set to "XXXX New Insteon Device Type" and wasn't
 doing anything.  It also (like the above) blank IEngine.
 I've tried changing that to Legacy, I2 and I2CS with no
 luck.  Each time when I save it the link creation items
 appear in the Pending Operations, but then there is a
 flash and they are all gone and the device is marked as
 disabled.  As best I can tell it doesn't show anything in
 the log.
 Thoughts?
 Here is the log (The 2457D2 ID is 1A DD 06):
 2012-12-06  14:14:03.857     RX  &nbs p;  INSTEON TIMEOUT=14 3C C3
 2012-12-06  14:14:05.482     TX  &nbs p;  02 62 14 3C C3 05 2B F1
 2012-12-06  14:14:05.529     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B F1 06
 2012-12-06  14:14:06.514     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 2B 2B 03
 2012-12-06  14:14:06.717     TX  &nbs p;  02 62 14 3C C3 05 2B F2
 2012-12-06  14:14:06.795     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B F2 06
 2012-12-06  14:14:07.920     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 23 2B 07
 2012-12-06  14:14:08.123     TX  &nbs p;  02 62 14 3C C3 05 2B F3
 2012-12-06  14:14:08.170     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B F3 06
 2012-12-06  14:14:08.373     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 21 2B E7
 2012-12-06  14:14:08.592     TX  &nbs p;  02 62 14 3C C3 05 2B F4
 2012-12-06  14:14:08.639     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B F4 06
 2012-12-06  14:14:13.951     RX  &nbs p;  INSTEON TIMEOUT=14 3C C3
 2012-12-06  14:14:14.045     TX  &nbs p;  02 62 14 3C C3 05 2B F4
 2012-12-06  14:14:14.107     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B F4 06
 2012-12-06  14:14:15.592     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 27 2B 23
 2012-12-06  14:14:15.795     TX  &nbs p;  02 62 14 3C C3 05 2B F5
 2012-12-06  14:14:15.842     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B F5 06
 2012-12-06  14:14:17.357     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 27 2B FF
 2012-12-06  14:14:17.592     TX  &nbs p;  02 62 14 3C C3 05 2B F6
 2012-12-06  14:14:17.654     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B F6 06
 2012-12-06  14:14:22.779     RX  &nbs p;  INSTEON TIMEOUT=14 3C C3
 2012-12-06  14:14:22.873     TX  &nbs p;  02 62 14 3C C3 05 2B F6
 2012-12-06  14:14:22.920     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B F6 06
 2012-12-06  14:14:24.420     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 27 2B 1F
 2012-12-06  14:14:24.639     TX  &nbs p;  02 62 14 3C C3 05 2B F7
 2012-12-06  14:14:24.701     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B F7 06
 2012-12-06  14:14:29.779     RX  &nbs p;  INSTEON TIMEOUT=14 3C C3
 2012-12-06  14:14:29.873     TX  &nbs p;  02 62 14 3C C3 05 2B F7
 2012-12-06  14:14:29.920     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B F7 06
 2012-12-06  14:14:30.889     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 27 2B 00
 2012-12-06  14:14:32.545     TX  &nbs p;  02 62 14 3C C3 05 28 0F
 2012-12-06  14:14:32.607     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 28 0F 06
 2012-12-06  14:14:37.639     RX  &nbs p;  INSTEON TIMEOUT=14 3C C3
 2012-12-06  14:14:37.732     TX  &nbs p;  02 62 14 3C C3 05 28 0F
 2012-12-06  14:14:37.779     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 28 0F 06
 2012-12-06  14:14:37.982     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 21 28 0F
 2012-12-06  14:14:38.170     TX  &nbs p;  02 62 14 3C C3 05 2B E8
 2012-12-06  14:14:38.248     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B E8 06
 2012-12-06  14:14:38.436     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 21 2B A2
 2012-12-06  14:14:38.639     TX  &nbs p;  02 62 14 3C C3 05 2B E9
 2012-12-06  14:14:38.701     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B E9 06
 2012-12-06  14:14:39.670     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 2012-12-06  14:14:39.873     TX  &nbs p;  02 62 14 3C C3 05 2B EA
 2012-12-06  14:14:39.889     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 23 2B 03
 2012-12-06  14:14:39.936     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B EA 06
 2012-12-06  14:14:40.139     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 21 2B 12
 2012-12-06  14:14:40.358     TX  &nbs p;  02 62 14 3C C3 05 2B EB
 2012-12-06  14:14:40.404     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B EB 06
 2012-12-06  14:14:40.608     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 21 2B C8
 2012-12-06  14:14:40.826     TX  &nbs p;  02 62 14 3C C3 05 2B EC
 2012-12-06  14:14:40.873     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B EC 06
 2012-12-06  14:14:42.842     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 2B 2B 5C
 2012-12-06  14:14:43.029     TX  &nbs p;  02 62 14 3C C3 05 2B ED
 2012-12-06  14:14:43.092     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B ED 06
 2012-12-06  14:14:43.623     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 22 2B FF
 2012-12-06  14:14:43.826     TX  &nbs p;  02 62 14 3C C3 05 2B EE
 2012-12-06  14:14:43.983     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B EE 06
 2012-12-06  14:14:44.889     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 27 2B 03
 2012-12-06  14:14:45.076     TX  &nbs p;  02 62 14 3C C3 05 2B EF
 2012-12-06  14:14:45.139     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B EF 06
 2012-12-06  14:14:46.592     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 2B 2B 00
 2012-12-06  14:14:48.373     RX  &nbs p;  RECEIVEINSTEONRAW=1C  4C
 96 00 00 01 C7 11 00
 2012-12-06  14:14:48.608     RX  &nbs p;  RECEIVEINSTEONRAW=1C  4C
 2012-12-06  14:14:49.576     RX  &nbs p;  RECEIVEINSTEONRAW=1C  4C
 96 00 00 01 C7 13 00
 2012-12-06  14:14:49.858     RX  &nbs p;  RECEIVEINSTEONRAW=1C  4C
 2012-12-06  14:14:57.186     TX  &nbs p;  02 62 14 3C C3 05 28 0F
 2012-12-06  14:14:57.233     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 28 0F 06
 2012-12-06  14:14:59.248     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 27 28 0F
 2012-12-06  14:14:59.436     TX  &nbs p;  02 62 14 3C C3 05 2B E0
 2012-12-06  14:14:59.498     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B E0 06
 2012-12-06  14:15:04.608     RX  &nbs p;  INSTEON TIMEOUT=14 3C C3
 2012-12-06  14:15:04.717     TX  &nbs p;  02 62 14 3C C3 05 2B E0
 2012-12-06  14:15:04.764     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B E0 06
 2012-12-06  14:15:05.264     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 26 2B A2
 2012-12-06  14:15:05.483     TX  &nbs p;  02 62 14 3C C3 05 2B E1
 2012-12-06  14:15:05.530     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B E1 06
 2012-12-06  14:15:05.748     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 21 2B 03
 2012-12-06  14:15:05.936     TX  &nbs p;  02 62 14 3C C3 05 2B E2
 2012-12-06  14:15:05.983     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B E2 06
 2012-12-06  14:15:06.248     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 21 2B 09
 2012-12-06  14:15:06.451     TX  &nbs p;  02 62 14 3C C3 05 2B E3
 2012-12-06  14:16:00.686     TX  &nbs p;  02 62 14 3C C3 05 28 0F
 2012-12-06  14:16:00.733     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 28 0F 06
 2012-12-06  14:16:00.983     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 2012-12-06  14:16:01.186     TX  &nbs p;  02 62 14 3C C3 05 2B D0
 2012-12-06  14:16:01.233     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D0 06
 2012-12-06  14:16:02.233     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 27 2B A2
 2012-12-06  14:16:03.374     TX  &nbs p;  02 62 14 3C C3 05 2B D1
 2012-12-06  14:16:03.436     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D1 06
 2012-12-06  14:16:04.046     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 2B 2B 04
 2012-12-06  14:16:04.249     TX  &nbs p;  02 62 14 3C C3 05 2B D2
 2012-12-06  14:16:04.311     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D2 06
 2012-12-06  14:16:04.858     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 22 2B 09
 2012-12-06  14:16:05.061     TX  &nbs p;  02 62 14 3C C3 05 2B D3
 2012-12-06  14:16:05.124     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D3 06
 2012-12-06  14:16:06.264     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 23 2B 4D
 2012-12-06  14:16:06.452     TX  &nbs p;  02 62 14 3C C3 05 2B D4
 2012-12-06  14:16:06.514     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D4 06
 2012-12-06  14:16:11.608     RX  &nbs p;  INSTEON TIMEOUT=14 3C C3
 2012-12-06  14:16:11.702     TX  &nbs p;  02 62 14 3C C3 05 2B D4
 2012-12-06  14:16:11.749     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D4 06
 2012-12-06  14:16:16.780     RX  &nbs p;  INSTEON TIMEOUT=14 3C C3
 2012-12-06  14:16:16.889     TX  &nbs p;  02 62 14 3C C3 05 2B D4
 2012-12-06  14:16:16.952     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D4 06
 2012-12-06  14:16:18.061     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 23 2B 36
 2012-12-06  14:16:18.280     TX  &nbs p;  02 62 14 3C C3 05 2B D5
 2012-12-06  14:16:18.343     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D5 06
 2012-12-06  14:16:18.546     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 21 2B 73
 2012-12-06  14:16:18.764     TX  &nbs p;  02 62 14 3C C3 05 2B D6
 2012-12-06  14:16:18.827     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D6 06
 2012-12-06  14:16:23.921     RX  &nbs p;  INSTEON TIMEOUT=14 3C C3
 2012-12-06  14:16:24.030     TX  &nbs p;  02 62 14 3C C3 05 2B D6
 2012-12-06  14:16:25.577     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 27 2B 1B
 2012-12-06  14:16:26.014     TX  &nbs p;  02 62 14 3C C3 05 2B D6
 2012-12-06  14:16:26.077     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D6 06
 2012-12-06  14:16:26.311     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 21 2B 1B
 2012-12-06  14:16:31.108     RX  &nbs p;  INSTEON TIMEOUT=14 3C C3
 2012-12-06  14:16:32.530     TX  &nbs p;  02 62 14 3C C3 05 28 0F
 2012-12-06  14:16:32.577     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 28 0F 06
 2012-12-06  14:16:32.827     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 2012-12-06  14:16:33.108     TX  &nbs p;  02 62 14 3C C3 05 2B D0
 2012-12-06  14:16:33.186     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D0 06
 2012-12-06  14:16:38.202     RX  &nbs p;  INSTEON TIMEOUT=14 3C C3
 2012-12-06  14:16:38.296     TX  &nbs p;  02 62 14 3C C3 05 2B D0
 2012-12-06  14:16:38.343     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D0 06
 2012-12-06  14:16:40.343     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 2012-12-06  14:16:40.561     TX  &nbs p;  02 62 14 3C C3 05 2B D1
 2012-12-06  14:16:40.624     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D1 06
 2012-12-06  14:16:45.733     RX  &nbs p;  INSTEON TIMEOUT=14 3C C3
 2012-12-06  14:16:45.843     TX  &nbs p;  02 62 14 3C C3 05 2B D1
 2012-12-06  14:16:45.905     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D1 06
 2012-12-06  14:16:47.358     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 2012-12-06  14:16:47.546     TX  &nbs p;  02 62 14 3C C3 05 2B D2
 2012-12-06  14:16:47.608     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D2 06
 2012-12-06  14:16:48.593     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 27 2B 09
 2012-12-06  14:16:48.796     TX  &nbs p;  02 62 14 3C C3 05 2B D3
 2012-12-06  14:16:48.858     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D3 06
 2012-12-06  14:16:50.843     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 27 2B 4D
 2012-12-06  14:16:51.061     TX  &nbs p;  02 62 14 3C C3 05 2B D4
 2012-12-06  14:16:51.108     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D4 06
 2012-12-06  14:16:51.671     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 22 2B 36
 2012-12-06  14:16:51.874     TX  &nbs p;  02 62 14 3C C3 05 2B D5
 2012-12-06  14:16:51.936     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D5 06
 2012-12-06  14:16:52.483     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 22 2B 73
 2012-12-06  14:16:52.671     TX  &nbs p;  02 62 14 3C C3 05 2B D6
 2012-12-06  14:16:52.733     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D6 06
 2012-12-06  14:16:53.280     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 22 2B 1B
 2012-12-06  14:16:53.483     TX  &nbs p;  02 62 14 3C C3 05 2B D7
 2012-12-06  14:16:53.546     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D7 06
 2012-12-06  14:16:58.655     RX  &nbs p;  INSTEON TIMEOUT=14 3C C3
 2012-12-06  14:16:58.733     TX  &nbs p;  02 62 14 3C C3 05 2B D7
 2012-12-06  14:16:58.780     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B D7 06
 2012-12-06  14:16:59.046     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 21 2B 00
 2012-12-06  14:17:22.280     TX  &nbs p;  02 62 14 3C C3 05 28 0F
 2012-12-06  14:17:22.327     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 28 0F 06
 2012-12-06  14:17:23.984     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 23 28 0F
 2012-12-06  14:17:24.155     TX  &nbs p;  02 62 14 3C C3 05 2B C8
 2012-12-06  14:17:24.234     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B C8 06
 2012-12-06  14:17:26.155     RX  &nbs p;  RECEIVEINSTEONRAW=14  3C
 C3 1F 57 60 2B 2B A2
 2012-12-06  14:17:26.374     TX  &nbs p;  02 62 14 3C C3 05 2B C9
 2012-12-06  14:17:26.452     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B C9 06
 2012-12-06  14:17:31.562     RX  &nbs p;  INSTEON TIMEOUT=14 3C C3
 2012-12-06  14:17:31.671     TX  &nbs p;  02 62 14 3C C3 05 2B C9
 2012-12-06  14:17:31.718     RX  &nbs p;  SENTINSTEON=1F 57 60 14
 3C C3 05 2B C9 06
           | Posted: December 06 2012 at 20:09 | IP Logged
The trace is reading link records from 14 3C C3 using the Legacy I1 method, one byte at a time.  No way to know what will happen after that as PH works with one device at a time.
 The FF.FF.Ff noted in an earlier post indicates the device being accessed is an I2CS device that PH does not know is I2CS.  A FF response often indicates the PLM is not authorized to communicate with the I2CS device.  One of the new characteristics of I2CS.
  Edited by grif091 - December 06 2012 at 20:13
           | Posted: December 07 2012 at 13:46 | IP Logged
Does that mean that I need to do something special between
 the PLM and the new Lamplinc to allow PH to program it?
           | Posted: December 07 2012 at 14:58 | IP Logged
Just out of curiosity you're not running SDM with the 2412. If not what device manager are you controlling it with?
           | Posted: December 07 2012 at 16:03 | IP Logged
I set it up just like your link...and after a little
 messing around it seems to work
 perfectly.  As for how it works, you'd have to ask dave.
 I really like it.
 For what it's worth, I had a circa 2007 PLC (Controller
 not Modem) and the new one is MUCH faster.  Double tap
 triggers work more like I expect them too (the PLC was
 probably ~.75 to > 1 sec to respond sometimes, it's not
 probably like .25 sec or less).
 I will say that I know which circuits have most of the
 Insteon Devices on them and it's not the dedicated
 circuit that runs over by the equipment rack.  I ran a
 network line and put the new one closer to those devices
 and off the known noisy circuit so that might have
 something to do with it (although really the rack has a
 powerstrip with amps and a UPS plugged into it so maybe
 it's not real noisy.)
 (Edited when I realized I was replying to BeachBum and he
 didn't need my link that he sent me.)
  Edited by traviskleckner - December 07 2012 at 16:04
           | Posted: December 08 2012 at 02:19 | IP Logged
OK, got it. I run a power strip plus UPS but I have it all plugged through a filterlinc to eliminate  any absorption of the signal which power strips do. Yes the PLM is lighting speed compared to a PLC. I've been fighting noise for years and I have one circuit that I have to use X10 on that insteon will not work because of the noise.
           | Posted: December 08 2012 at 06:34 | IP Logged
I had the amps and UPS on a FilterLinc for a while (back
 when there were about 10 Insteon devices in my house) but
 then for some reason it started humming so I eliminated it.
 I've got more like 60 devices now, and they are pretty
 evenly distributed to every room in the house and I rarely
 if ever have a problem.
 I wonder if all these dual-band devices are going to help
 with that?  My experience so far has been that the range on
 the RF communications isn't good, but if all my devices (in
 particular all my SwitchLincs were RF too, it might make
 quite the difference.
           | Posted: December 08 2012 at 11:41 | IP Logged
I've come to the same conclusion that the range is not that good. Maybe line of sight and 1 wall.  My primary noise comes from trac light systems. I have a macro  that sets the indicated level then checks against the real level at the device and resends if there is a problem. I know Jeff used a similar approach with his environment. I don't know if the rf signal will overpower the line signal at the receive. Maybe Lee can shed some light on that subject. From my experience the old APs had better range. With 60 devices you should own stock in Smarthome.
           | Posted: December 08 2012 at 12:13 | IP Logged
Well, after quite a bit more messing around I think I
 might just have a bad LampLinc.  I've e-mailed Smarthome
 so we will see what they say.
 What's interesting is that in PH the device is check
 disabled.  When I uncheck it and save then the pending
 commands show up in the list (there are several links to
 build) but then the first command shows up in the recent
 list but it didn't actually happen.  The Insteon log (and
 the PH Log) shows nothing, no TX or RX to that address.
 And the device is back to disabled.  I've tried changing
 the protocol from Legacy, I2 and I2CS and I get the same
 results.
 I used the web interface on the 2412 and while I can
 setup that LampLinc in a scene, it never responds to the
 commands from the 2412.  If I use the local control
 buttons to turn it on, and the refresh the screen on the
 2412 I can see the status reflect the change.
 Interestingly, once it's on, the 2412 can turn it off,
 but never back on.  The only device that can link to it
 and consistently control it is the RF Remote.  I'm
 wondering if the powerline communications part is somehow broken or corrupted.
