Subject Topic: Lights blink when turning them on Post ReplyPost New Topic
MrGibbage
Posted: December 13 2013 at 05:36 | IP Logged Quote MrGibbage
Sometimes when I turn my kitchen lights on (Insteon, of
course), they blink a couple of times before staying on.
They are controlled by a KPL (direct load). This just
started recently. Any idea what could cause the blinking
and is there a way to make it stop? I'll see if I can
capture a log of when it happens, but I am hoping it has
an easy solution that someone here will instantly
recognize.
Skip
Posted: December 13 2013 at 07:40 | IP Logged Quote smarty
Skip,
Just something to try.....
With some of my older KPL's,...once in a great while I will see something like this. Usually doing an "air-gap" to completely clear and refresh the KPL device (and then using PH to rebuild all the links) seem to clear it up.
Steve
MrGibbage
Posted: December 13 2013 at 15:43 | IP Logged Quote MrGibbage
OK, I air-gap reset it and so far so good. If it happens
again, I'll try and capture it in a log.
Skip
