jeffw_00 Super User
| Posted: August 02 2014 at 09:22 | IP Logged
Hi - I had a macro that trimmed my event log to 15 days once a week. I just discovered it stopped working back in December 2013(!). The error it generates is
AN error occurred while trimming the eventlog table.
SQLSTATE = S1000
[Sybase][ODBC Driver][Adaptive Server ANywhere]General error: Unable to find in index 'eventlog' for table 'eventlog'
How do I fix? (Still running 2.1.4) if I have to clear the entire log that's cool.
| Posted: August 04 2014 at 19:59 | IP Logged
Jeff,
Looks like the database (eventlog) is corrupt (probably grew to large).
Since you're on version 2.1.4, I would run the Database upgrade utility and check the option to not migrate eventlog entries. This will rebuild and compact your database and should fix your problem.
An alternative would be to update to version 2.1.5a which will not bring over your eventlog entries (you'll start fresh). Additionally, this version separates out the eventlog into its own database so if it does corrupt or grow too large, it won't affect your other configuration data.
jeffw_00 Super User
| Posted: August 04 2014 at 20:14 | IP Logged
Hi Dave - Thanks! No offense, but I'm going to let others bolder than me beta 2.1.5 for a bit (I'm flat out at work so I just need things to run). Sounds like one option is to do nothing until I upgrade, but - if i ran the Database upgrade utility (after making a copy of my PH folder, of course), I don't mean to be dim, but what is the exact command? Do I just double-click on phupg.exe in the powerhome (2.1.4) folder?
| Posted: August 04 2014 at 20:42 | IP Logged
Jeff, quick answer is yes. That should fix it.
jeffw_00 Super User
| Posted: August 04 2014 at 20:53 | IP Logged
ok. thx. will try it soon
jeffw_00 Super User
| Posted: August 08 2014 at 11:44 | IP Logged
fixed it -thanks!
RichardL Senior Member
| Posted: August 12 2016 at 16:50 | IP Logged
I trim my Event log nightly, so all has been well. Was doing some maintenance and disabled the timed event to trim the log, then forgot to re-enable it. So...now my PHLogs.DB is 177MB.
I ran PHUpg.exe, saw it run by many tables, and it rebuilt my pwrhome.db file from 4MB to 3MB, good, but my PHLogs.DB is still 177MB.
I tried to delete it and when I start PH I get challenged with a login for the database, which I do not know. Even if I go around that, PH does not start. Put the PHLogs.db file back for now.
Any way to shrink the PHLogs.DB file?
Thank you.
Richard
| Posted: August 12 2016 at 18:54 | IP Logged
Richard,
You're on the right track. Go ahead and delete the
phlogs.db file and then copy the phlogs10.db (in the
same directory) to phlogs.db.
The phlogs10.db is just an empty logs file for just this
type of situation .
| Posted: August 13 2016 at 09:31 | IP Logged
Beautiful! That worked fine.
Thanks so much for the quick reply.
