MrGibbage Super User
| Posted: September 16 2015 at 05:30 | IP Logged
My front porch light has all of a sudden started doing something strange. Whenever I turn any other light
in the house on or off, the front porch light blinks once or twice. Would this indicate a problem with the
switch or with the PLM? Or something else? I did some raw captures to see if there were any clues. I turned
my study light on and off a few times and captured the insteon traffic and the PH logs here.
Raw Log:
2015-09-16 04:54:31.851 TX &nbs p; 02 62 1D 36 B6 0F 13 00
2015-09-16 04:54:31.911 RX &nbs p; SENTINSTEON=14 85 10 1D 36 B6 0F 13 00 06
2015-09-16 04:54:32.204 RX &nbs p; RECEIVEINSTEONRAW=1D 36 B6 14 85 10 2B 13 00
2015-09-16 04:54:35.591 TX &nbs p; 02 62 1D 36 B6 0F 11 FF
2015-09-16 04:54:35.635 RX &nbs p; SENTINSTEON=14 85 10 1D 36 B6 0F 11 FF 06
2015-09-16 04:54:35.928 RX &nbs p; RECEIVEINSTEONRAW=1D 36 B6 14 85 10 2B 11 FF
PH Log:
INSTEON PLM Controller PLM transmission of Address:[1D.36.B6] Flags:[15] Cmd1:[19] Cmd2:[0]. Decode:
Direct. ID: STUDY, Off
Incoming Insteon received on INSTEON PLM controller PLM. From Address:[1D.36.B6] To Address:[14.85.10]
Flags:[43] Cmd1:[19] Cmd2:[0]. Decode: Direct ACK. From: STUDY To: PLMCTLR1, Off
INSTEON PLM Controller PLM transmission of Address:[1D.36.B6] Flags:[15] Cmd1:[17] Cmd2:[255]. Decode:
Direct. ID: STUDY, On
Flags:[39] Cmd1:[17] Cmd2:[255]. Decode: Direct ACK. From: STUDY To: PLMCTLR1, On
Flags:[43] Cmd1:[17] Cmd2:[255]. Decode: Direct ACK. From: STUDY To: PLMCTLR1, On
I don't see any traffic pointing to the front porch light, so it's like it never happened, but it is
definitely blinking every time I do something.
Any suggestions?
__________________ Skip
| Posted: September 16 2015 at 07:24 | IP Logged
Watching this! I have a lamp module doing this now.
| Posted: September 16 2015 at 09:18 | IP Logged
Ive had very similar problems happen a couple of times
(a switch doing something crazy with Insteon traffic).
Both times ended up being the switch itself and not the
PLM.
nick7920 Senior Member
| Posted: September 16 2015 at 19:23 | IP Logged
I had similar once or twice both time switch - had to
factory reset the switch. some switch also has x10
address would also check that.
Nick
| Posted: September 17 2015 at 07:41 | IP Logged
I also have lamp module 2672-222 Insteon LED doing the same thing. I'll do some trouble shooting and see if I can get closer to the issue.
