aw311junkie Groupie
Online Status: Offline Posts: 43
Posted: February 14 2006 at 22:47 | IP Logged
this may take a while so it may be better in chat...but i wa sunder the impression this program would be easy to use, and i just started it up and im very lost...anyone want to get me started..how to make on/off controls for my modules with x10 stuff and how to control from the web..i want a very basic online on/off setup thats it
Posted: February 14 2006 at 23:21 | IP Logged
You can do just about anything you like with the web interface using PSP. However, this is more of an advanced concept. You can also do this type of thing using just static HTML calling standard PowerHome CGI commands. But the easiest for your situation, just basic On and Off of X-10 controls would be just to use the Control Center.
From the PowerHome Explorer, navigate to "Control Center" and create a Control Center tab. Basically, just give it an ID (something meaningful such as "X10 CONTROL") and set the tab order > 0. Click on the little button on the far left of the line you just created. You should now be in "Control Center Button Details". For your first button, type a valid "Key Description" and choose a button type of "X-10". Next select the ID of the X-10 device you wish to control (you did already create your X-10 devices in the "Devices" section of the Explorer, didn't you ). Select the type of Key (on, off, dim, bright) and press "F5" to save your changes.
If you've activated the webserver (Setup->Web in the Explorer), then just use this URL in your web browser: http://127.0.0.1/ph-cgi/controlcenter? and you should see your single X-10 Control Center button.
Now all you have to do is create more buttons using the same screens above. Note though that all your buttons will initially be created in the upper left hand corner stacked one on top of the other. To fix this, after saving your changes in the Explorer (the "F5" key), open the Client Control Center by pressing "Alt-F1". If it's already open, then close it and reopen it. You'll see what appears to be a single button. Right-click on the Control Center and choose "Open Design View". A new window will open allowing you to design your button layout including colors, size, location. To quickly just space all the buttons out so you can see them and work with them easier press "Shift-F11". From there you can turn on "drag and drop" mode and move and resize the buttons to your liking. Press "Shift-F12" to save your changes and the next time you bring up the above URL in your browser, you'll see your changes.
This will be the easiest, non-programmatic method of getting simple on/off X-10 button control via the web.
Let me know how it goes,
aw311junkie Groupie
Posted: February 15 2006 at 23:21 | IP Logged
i cant get the web part to work help me out please
aw311junkie Groupie
Posted: February 15 2006 at 23:28 | IP Logged
it says communication with server failed
aw311junkie Groupie
and on my desktop nothing loads
Posted: February 16 2006 at 00:16 | IP Logged
What is saying "communication with server failed". Is it Internet Explorer?
From the PowerHome Explorer, navigate to Setup->Web. Make sure that the web server is enabled. Check the port setting. If you're not running any other web server on the PowerHome machine then set the port to 80. Be sure that you type in a Master UserID and Password. If you make any changes to this page then either restart or reinitialize PowerHome.
On the same machine as PowerHome, launch Internet Explorer. In the address field, type: http://127.0.0.1 and press enter. You should be prompted for a userid and password. Enter the master userid and password that you typed in the web setup screen. You should then see the web version of the Device Status screen. If you do, then you can click on "Control Center" in the menu and see if that comes up. If not, then we'll have to troubleshoot further.
aw311junkie Groupie
Posted: February 16 2006 at 15:02 | IP Logged
so it only works at the home computer? i thought it was accessible anywhere
Posted: February 16 2006 at 16:03 | IP Logged
No, it can work from anywhere. He is just staring the troubleshooting process from the beginning.
aw311junkie Groupie
Posted: February 16 2006 at 16:44 | IP Logged
ok ill try tonight when i get home and get back on and tell you how it goes(around 7:30)
aw311junkie Groupie
Posted: February 16 2006 at 19:59 | IP Logged
still cant get it to work
the page will not load in internet explorer..i typed in the http://127.0.0.1 and it doesnt work..i enable the web server on port 80..nothin
aw311junkie Groupie
Posted: February 16 2006 at 20:07 | IP Logged
do I need to change the port or enable port forwarding or something?
Posted: February 16 2006 at 20:13 | IP Logged
If you are trying to access PowerHome from Internet Explorer on the PowerHome machine, then no, port forwarding wont matter. Is it possible that you are running some form of personal firewall such as zone alarm on the PH machine? If so, then you will have to allow PH to act as a server.
You can also try changing the port just in case there is a conflict. In the settings window, change the port to 8000. Reinitialize PowerHome. Open IE and use the following: http://127.0.0.1:8000
Let me know how that goes.
aw311junkie Groupie
Posted: February 16 2006 at 20:32 | IP Logged
ok i got it on the home computer..now is it accessible from other computers like at school and on other networks
aw311junkie Groupie
Posted: February 16 2006 at 20:51 | IP Logged
can we do this in a chat so i can get it done easier?
aw311junkie Groupie
Posted: February 16 2006 at 21:05 | IP Logged
nevermind i figured it out with port forwarding on my router..thanks for the help ill contact you if i have any other questions
Posted: February 16 2006 at 22:16 | IP Logged
Heh,
Guess I was too slow getting back to the board .
Anyways, Im glad you got it working. As you've found out, to access from outside your network, you play with the port forwarding on your router.
Let me know if you have any other problems or questions.
