QuickCarl Groupie
Posted: March 02 2006 at 08:01 | IP Logged
Any ideas?
log:DM=active,1.01.20.157,2/27/2006 8:14:21 AM,responded,00.D4.33,2.12
(continued)
ui:srq:srir=00 00 00 03 07 05 0F 19 00
PLC:eventraw=02
PLC:eventraw=03
PLC:receiveinsteonraw=02 01 6F 19 00 00 01 CB 17 00
PLC:eventraw=03
ui:srir=00 00 00 01 78 C5 0F 11 50
ui:srir=00 00 00 00 4F CE 0F 11 FF
ui:srir=00 00 00 00 4F C7 0F 11 FF
Everything was working fine until this AM. All my timed macros ceased after last night.
Posted: March 02 2006 at 10:29 | IP Logged
Yep,
This is the classic "after SDM runs awhile, it stops responding to commands" problem. Ive read messages from several people (using other software) that see the same thing. How many days were you able to stay up continuous with version 163?
From what Ive read, it seems to be a problem with the amount of data that goes back and forth with the SDM. If you've already scanned all of your links and you're not using tap-tap linking and instead do all your linking from PowerHome, you should be able to turn off the "Background Status Check", "Background Local Level Scan", and "Background Database Scanning" in the Insteon Controller Settings window. This will greatly reduce your SDM traffic and might even get you a couple of weeks out of the SDM before it needs to be restarted (and hopefully by then SmartHome will have a version that doesnt have this problem ).
QuickCarl Groupie
Posted: March 02 2006 at 10:54 | IP Logged
Dave, I don't think I have version 163 of the SDM.
I will turn off all the checking though. It ran fine for about 3 days.
I just order 21 more Insteon switches for install...
Posted: March 03 2006 at 14:05 | IP Logged
Carl,
Sorry, I got confused (it's easier and easier these days ).
3 days with polling on that version is pretty good. Based upon other tests, it should be MUCH better in the next version.
21 switches , Holy smokes, you guys are getting way ahead of me. I just ordered about 10 more but don't know when I'll even find time to install them .
