Subject Topic: usb-uirt Post ReplyPost New Topic
aw311junkie
Posted: March 26 2006 at 00:14 | IP Logged Quote aw311junkie
got my usb-uirt today anyone wanna get me started?
Back to Top View aw311junkie's Profile Search for other posts by aw311junkie
Posted: March 26 2006 at 01:42 | IP Logged Quote TonyNo
Dave gave me this info a while ago for setup...
Quote:
It's pretty simple...just be sure to install the drivers for the USB-UIRT (from their website). After that, just select it within PowerHome, reinitialize, and then go to Help->About->Controllers and you should see it listed.
Also, take a look at page 45 of the PH manual.
Let us know if you have more questions!
aw311junkie
Posted: March 26 2006 at 18:49 | IP Logged Quote aw311junkie
aight i set it up. i did 15 commands in one ir thing. i did 0-9 on vol up vol down chan up chan down. the first one i tried was tv on/off and it worked. my tv turned on. then i tried 66(for comedy central) i tried to do 6 two times and neither one showed up. i looked at my screen as i tried it a third time and it said code malfunction. from there on out, all codes were malfunction error, including the on/off that had worked previously. help anyone?
Posted: March 26 2006 at 19:09 | IP Logged Quote TonyNo
Are you running with the recent patches to PH? I recall there were some UIRT issues.
aw311junkie
Posted: March 28 2006 at 21:49 | IP Logged Quote aw311junkie
ok i screwed up the update ill just delete all and redownload the new version and start my project from scratch and try the uirt again. also, just curious whats the deal with voice recognition. multiple microphones places in rooms?just while sitting at computer?web control?how do you set it up. anything special needed?
aw311junkie
Posted: March 28 2006 at 22:23 | IP Logged Quote aw311junkie
crap..i now have the new one...not only does my uirt not want to auto learn, i get critical errors for almost everything and my x10 doesnt even work i dont think it recognizes my cm17a. now i have no x10 support and nothing will wake me up at 6:44 tomorow for school
Posted: March 28 2006 at 22:39 | IP Logged Quote TonyNo
What version were you running before the upgrade?
aw311junkie
Posted: March 28 2006 at 22:41 | IP Logged Quote aw311junkie
10344 but i completely deleted it and downloaded the new version cuz the upgrade seemed intimidating
Posted: March 28 2006 at 22:45 | IP Logged Quote TonyNo
OK, the upgrade changed the way the controllers are used. I think you just need to set them up again.
Posted: March 28 2006 at 23:08 | IP Logged Quote TonyNo
FYI: We took care of this via chat. He was not first defining his IR Devices.
Posted: April 04 2006 at 18:16 | IP Logged Quote dhoward
Glad all is working. Thanks Tony...I think now you're DA MAN!!
