Posted: June 07 2002 at 12:03 | IP Logged
Kent,
Its quite possible...I dont use Instant Messenger or Windows Messenger so I dont know what indication they give that an incoming message is waiting. What kind of indication do they currently give? I'll do some research on the web and see if its something that I can hook into so that a trigger is fired. Assuming that PowerHome can know that a message is waiting, it could certainly handle the flashing lights or any other indicator.
If the messenger currently opens a window that a message is waiting, PowerHome could probably do what you want as is, but it would probably be cleaner if I can hook directly. I'll post back any info that I find.
