sifu128 Groupie
Online Status: Offline Posts: 62
Posted: March 18 2016 at 18:17 | IP Logged
Hey everyone! We had a bad storm about 2 weeks ago and the power went out several times and fried my 2413U. I ordered a new one and it just came in today. Old one was set to COM 4 and it seems after a factor reset this one defaults to COM 1.
When I try to connect to it PH will just keep failing with Get IM Info command failed for Insteon PLM1. PH doesn't log anything.
Is there anything I can do to figure out why it shows connected but will not display or connect to anything?
I did go in to the devices and change the hardware address from the old to the new, saved it and also download the links, still no go.
TIA
Dave
nick7920 Senior Member
Posted: March 20 2016 at 11:32 | IP Logged
I would try this first.
COM1 is not a good idea most of the time you would have
built in serial port set to COM1 - I would try setting
back to COM4 you have to first change it in device
manager and then into power home. 2413U is a usb to
serial and requires driver which you should already
have.
Nick
Posted: March 23 2016 at 15:59 | IP Logged
Just wondering if Nick's advice helped or not.
Let me know and we'll get you going again.
