Posted: April 08 2004 at 07:38 | IP Logged
Is there anything wrong with this formula?
ph_backupdb ( "c:\ph.db", 1)
This hangs PH for me.
Thanks - Tony
Posted: April 08 2004 at 10:02 | IP Logged
That formula should work fine. I tested several times on my machine without a problem.
When it hangs, how do you recover? Do you have to reboot, just exit PowerHome, etc. Also, where was the formula run from? I did my testing from the Formula Evaluator under the Control Menu.
Posted: April 08 2004 at 19:14 | IP Logged
I just run it from a macro; trying to automate the backup. When it hangs, I eventually get a critical error. I though those were e-mailed to you?
Posted: April 08 2004 at 20:45 | IP Logged
Nahhh,
The critical errors aren't automatically emailed. You have to click the link to email them and it just copies all of the relevant info into the body of email for you automatically. Just saves you having to type it in or doing a screen print and sending that.
I'll experiment some more and try running it from a macro. When you run it from a macro, is it in a formula all by itself, or is it part of a larger equation?
Posted: April 08 2004 at 23:53 | IP Logged
I have tried a formula and a message box with the same results. No other code in the macro.
Tony
Posted: April 14 2004 at 14:06 | IP Logged
Im back and trying to catch up...is this still a problem? When it critical errors, can you pass that along to me?
Posted: April 14 2004 at 20:25 | IP Logged
Sure, I'll pass it on. I just sent you one, but, for a different reason! That was the first time I saw the dialog box giving the option to send an e-mail.
Tony
patc Groupie
Posted: May 14 2004 at 21:52 | IP Logged
I also ran ph_backupdb as:
ph_setvar_a(2,1,ph_backupdb( "C:\PowerHome Stuff\dbXX1", 1 ))
var(2,1) got the return code as +1.
When I minimized PH it froze. I could kill Sybase but I couldn't kill PH via the Win Task Mgr. I next tried a shutdown that took an agonizingly long time but did shutdown. After rebooting, PH came up ok.
<SCRIPT language=javascript>postamble();SCRIPT>
__________________ PatC
Posted: May 17 2004 at 21:02 | IP Logged
Pat and Tony,
Ive been playing around with this and I can make it crash everytime .
Apparently a bug has creeped into the ph_backupdb function and it currently is not working. So far, I have not been able to run it and have it work correctly so I would refrain from using this function until the next release.
The next release should be available within about 4 weeks. The last release was a little hasty and did not get my full testing.
