Posted: March 02 2006 at 20:19 | IP Logged
I just noticed that navigating to http://ip:port only pulls the header info. Using http://ip:port/ph-cgi/main works.
Posted: March 03 2006 at 11:21 | IP Logged
I just tested this and it worked fine for me. Is it possible that you have an index.htm or index.psp file that is being picked up?
The way the ip:port only is interpreted is to first look for either an index.htm or index.psp file. If these are not found, then it will default to /ph-cgi/main.
Let me know,
Posted: March 03 2006 at 13:30 | IP Logged
Ah ha! I just downloaded the version of index.psp that you posted in another thread a while back...
Never mind!
Posted: March 03 2006 at 13:57 | IP Logged
Heh,
No problem
