ke6wue Newbie
Posted: October 05 2012 at 03:42 | IP Logged
I have been using Powerhome for a while and love it.
However, after several years I am finally bumping up
against some needs that don't seem to be available as
part of the control center. I know that some of this
stuff can be done with a custom html interface, but I'd
prefer to use the control center.
1) I have a whole home audio set up with an Extron 8x8
switcher. However, I have not found a good way to select
mp3 playlists. Ideally, I'd like drop-down boxes that
can be populated with playlists, with the playlist
selected serving as a variable which can be sent to
winamp. It'd also be nice if these could be populated
dynamically with directories (Select directory in box 1,
which populates box 2. Selecting a directory in box 2
populates box 3 and so on).
2) Some sort of an iframe (or other container)
implementation to allow embedding (and transmitting to
remote control centers) of a webpage such as pandora.
3) I know that this has been requested before, but I
could really use sliders that can be used to dynamically
set light levels and as a volume control. It'd also be
nice if these could be used horizontally to jump to a
specific location in an mp3 track.
4) Album art implementation (this may already be possible
-- I haven't spent a whole lot of time pursuing this one)
5) ZWave (secure implementation for Schlage front door
lock)
I know that this is a lot of stuff... but if you can do
anything to get some of it integrated (or tell me how to
do it if it is already possible) it would be much
appreciated!
Again, thanks for all of your hard work!
Jeremy
