nadler Super User
Posted: August 11 2006 at 09:53 | IP Logged
I notice in the manual for the new smarthome software, Houselinc, they have double click implimented. This allows you, for example, to turn off all lights in a room by double clicking off or just the controled device if you press off only once. Any chance this can be implimented in PH (without flags and macros and such)?
Posted: August 11 2006 at 12:38 | IP Logged
An Insteon double-tap sends a Fast On or Fast Off; you can set up triggers to do whatever you want when those are received.
nadler Super User
Posted: August 11 2006 at 12:51 | IP Logged
Wow. I've been using Insteon since day 1 and PH for a long time. I never knew that. I knew they were different but never realized it was because of the double tap. I will have to put that into my PH tips and tricks document. And, of course, it just continues to confirm that Dave is WAY AHEAD of smarthome's application.
Thanks (again).
ginigma Senior Member
Posted: August 16 2006 at 14:42 | IP Logged
nadler,
Anyway a PH newbie could convince you to post your tips and tricks doc?
