ginigma Senior Member
Posted: January 10 2007 at 22:25 | IP Logged
I'm trying to put the functions of a ControLinc (5 button) on a CC tab. I understand there is no direct call so I would have to use a formula. I was thinking of ph_insteonrawgroup, but it looks like that only controls groups on a PLC. Is that correct?
cmhardwick Senior Member
Posted: January 11 2007 at 08:48 | IP Logged
You can only control PLC groups
If you want to control the same lights as the controlinc does, you'll have a to create a duplicate group in the PLC.
HTH
Posted: January 17 2007 at 22:25 | IP Logged
Ginigma,
Cicero has you covered. Ive requested to SmartLabs that they make an extension to the Insteon protocol so that the PLC can "trigger" another devices stored groups but I don't think we'll be seeing it anytime soon. Since an Insteon device cannot tell another Insteon device to send it's "group" command, you'll have to duplicate that group as a PLC group and call that instead.
