Tomcat7194 Newbie
Posted: February 01 2007 at 22:06 | IP Logged
Hey everyone. I'm trying to run a pretty simple bit of code, and for some reason it's not cooperating. Basically, I want a macro that checks the global variable HEATON, and if it equals 1, changes it to zero, runs and x10 command, and does a tts.
Here is the code:
Formula | Immediate| if({HEATON}=1, ph_x10btn ("3", 3, 0 ) + ph_tts("Furnace is on") + ph_setglobal_s("HEATON","0"), 0)
When I run it with HEATON set to 1, it does not chance HEATON to zero, and it doesn't do the other functions. Any idea what I'm doing wrong here?
Tom
Viper Groupie
Posted: February 01 2007 at 22:26 | IP Logged
Use:
Goto Label | if ({HEATON}=1, "HEATON", "HEATOFF")
Label | HEATON
Set Global | "HEATON" | 0
Formula | Post | ph_x10btn("3",3,0)
Formula | Post | ph_tts("Furnace is on")
Label | HEATOFF
Posted: February 07 2007 at 21:58 | IP Logged
Tom,
I pasted your formula in the Multi-Editor and it worked just fine (once I created a global variable called HEATON and changed the "3" in ph_x10btn to match an X10 device in my setup) so Im not sure what the problem would be. All of the functions you're calling return integers so that is not a problem with adding them together. Have you any additional info to add?
You could also use Vipers suggestion. It should work as well.
