Tomcat7194 Newbie
| Posted: April 19 2007 at 20:45 | IP Logged
Hello. I would like to post some macros on a website in such a way that a user can simply paste the code in the multieditor and hit go in order to install the macro. Is there an easy way to export such code from ph?
Tom
| Posted: April 19 2007 at 22:02 | IP Logged
The usual way is to post the exported SQL.
Select Macro in the PH explorer, right-click on the macro name, and select Export.
You can then open this in a text editor and copy it.
jpcurcio Senior Member
| Posted: April 21 2007 at 02:58 | IP Logged
You can then open this in a text editor and copy it. |
Whenever I right-click anywhere in the PH Explorer, the right-hand pane grows such that the left-hand pane disappears. There is no way to select anything.
Is there an alternative way to do this?
-john
| Posted: April 21 2007 at 09:39 | IP Logged
No, you are clicking in the left pane (that maximizes the right pane). I was not clear enough...
Right-click on the right side on the macro name you want to export.
| Posted: April 21 2007 at 18:46 | IP Logged
OK... I'm just dense, I guess...
Yes, this works. Thanks for the explanation, and your patience with n00bs.
-JPC
