Subject Topic: "get weather" macro issues Post ReplyPost New Topic
jpcurcio
Posted: April 23 2007 at 02:47 | IP Logged Quote jpcurcio
I've been trying to use the "get weather" macro posted by TonyNo, and run up against a couple issues. The "current forecast" doesn't seem to work reliably, and I think I found the issue. My problem is that I don't know how to fix it.
When the macro grabs the forecast, it inevitably overruns the 1024 character limit of the CURFORECAST global variable. If this happens without properly closing a statement (such as a <img src="http://), it won't parse the variable properly in PH and therefore won't announce the weather.
Has anyone found a workaround for this? My first thought was to dump the wunderground image text, since it's useless for use in PH, but that would probably be difficult
Posted: April 23 2007 at 07:40 | IP Logged Quote TonyNo
I've not seen this, so I'm interested in anyone else having this problem.
Something like this should do it...
SET SYSTEM [LOCALx] ph_replaceallregex( "<img ~255>", "", [LOCALx], 0)
jpcurcio
Posted: April 23 2007 at 12:09 | IP Logged Quote jpcurcio
That sounds like it will work... but it raises (yet another) question. Can I nest the ph_regexdiff() statement used to grab the forecast inside the ph_replaceallregex()? I'm assuming that I can...
-JPC
nadler
Posted: April 23 2007 at 13:56 | IP Logged Quote nadler
I use the following weather macro which I copied from this board and have used for over a year. I think it was written by TonyNo and then he subsequently modified it to the macro you are using now. I only offer it because I note that it snaps the forecast differently and might be of some help.
insert into macroheader values ('GET WEATHER','GET WEATHER',1,1,1);
insert into macrodetail values ('GET WEATHER',1,37,'',NULL,'The next line snaps out the temperature in degrees farenheight.',0,'');
insert into macrodetail values ('GET WEATHER',2,15,'[LOCAL1] ',NULL,'ph_geturl("http://www.weatherunderground.com/cgi-bin /findweather/getForecast?query=11733")',0,'');
insert into macrodetail values ('GET WEATHER',3,15,'[LOCAL2] ',NULL,'ph_regexsnap("<nobr><b>\(.+\)</b>& nbsp;°F</nobr>","[LOCAL1]",1,0)',0,'');
insert into macrodetail values ('GET WEATHER',4,37,'',NULL,'The next line uses the regexdiff function to get the humidity.',0,'');
insert into macrodetail values ('GET WEATHER',5,15,'[LOCAL3] ',NULL,'ph_regexdiff(">Humidity:</td>~255<nobr&g t;<b>","%</b></nobr>"," [LOCAL1]",1,0)',0,'');
insert into macrodetail values ('GET WEATHER',6,37,'',NULL,'The next line gets wind in miles per hour.',0,'');
insert into macrodetail values ('GET WEATHER',7,15,'[LOCAL4]',NULL,'ph_regexdiff(">Wind Gust:</td>~255<nobr><b>","</b>  ","[LOCAL1]",1,0)',0,'');
insert into macrodetail values ('GET WEATHER',8,37,'',NULL,'The next line gets the current forecast.',0,'');
insert into macrodetail values ('GET WEATHER',9,15,'[LOCAL5]',NULL,'ph_regexdiff(''<h4>Updated:~255<div id="b">~255<div>'',''</div>'',"[LOCAL1]",1,0)',0,'');
insert into macrodetail values ('GET WEATHER',10,41,'ITUNES MUTE',NULL,'',0,'');
insert into macrodetail values ('GET WEATHER',11,9,'',NULL,'"Temperature: [LOCAL2] degrees~r~n.Humidity: [LOCAL3]%~r~n.Win[LOCAL4] miles per hour~r~n.Forecast: [LOCAL5]."',0,'');
insert into macrodetail values ('GET WEATHER',12,31,'',NULL,'20',0,'');
insert into macrodetail values ('GET WEATHER',13,9,'',NULL,'"Once again, the Temperature is. [LOCAL2] degrees"',0,'');
insert into macrodetail values ('GET WEATHER',14,31,'',NULL,'5',0,'');
insert into macrodetail values ('GET WEATHER',15,41,'ITUNES MUTE',NULL,'',0,'');
Posted: April 23 2007 at 14:02 | IP Logged Quote TonyNo
Hmm. That may work.
Thanks Nadler.
jpcurcio
Posted: April 23 2007 at 14:36 | IP Logged Quote jpcurcio
TonyNo wrote:
Hmm. That may work.
The main reason I want to do this is in order to grab as much of the forecast as possible. For each line in the forecast, there is a longer line containing the URL of the graphic. I figure that if I kill the <img src....> stuff first, I'd get more of the broadcast to fit into the variable. Once it gets stored, it will get truncated...
I tried the nesting briefly this morning before heading to work, but it didn't work. I'll investigate further tonight, when I have some time.
I'll also try Nadler's code as well, to see if that makes it better.
-jpc
jpcurcio
Posted: April 23 2007 at 23:05 | IP Logged Quote jpcurcio
OK... I've got it now. I used the ph_replaceallregex() function suggested by Tony, and filtered out the image text. I also nested the ph_regexdiff() inside the ph_replaceallregex() for conciseness. This will allow me to get the entire forecast string in the one variable without overflowing.
Here is the code snippet that I used:
ph_replaceallregex(
'<img src=.*~255 >',
ph_regexdiff(
    '<b>Forecast as of~255<td align="left">',
    '<div align',
    "[LOCAL1]",
    1,
    0
0
Thanks again for the help, guys... couldn't have done it without you!!
-JPC
krommetje
Posted: October 17 2009 at 05:41 | IP Logged Quote krommetje
Hey guys,
I can't seem to be able to extract the windspeed (Wind direction is OK) out of the following page:
mobile.wunderground.com/global/stations/06370.html
Like I said: I can get the direction out but the speed keeps on being empty.
I tried this amongst other things:
ph_regexsnap('at~255<span class="nowrap"><b>\(.+\)</b> mph</spa n>',"[LOCAL1]",1,0)
can you help me with this?
Posted: October 17 2009 at 09:26 | IP Logged Quote BeachBum
What happens when you narrow it down?
ph_regexsnap('mph</span>',"[LOCAL1]",1,0)
krommetje
Posted: October 17 2009 at 13:16 | IP Logged Quote krommetje
You've got to see it to believe it:
Oct 17 2009       19:13:59       User Message      4.0
Oct 17 2009       19:13:59       Global Variable      Global variable WIND changed from NNW to 4.0
Oct 17 2009       19:13:57       Macro    & nbsp; Macro WINDS executed.
BULLSEYE: You hit the spot right-on!
I am going to try this the following days!
Keep you informed....
Edited by krommetje - October 17 2009 at 13:18
krommetje
Posted: October 18 2009 at 06:32 | IP Logged Quote krommetje
I have a snipped javascript which calculates the Winchill from Temperature and windspped, I would like to convert this into a PH-like formula:
function doSteadman(temp, speed) {
   // Berekening van de wind-chill equivalent temperature volgens Robert G. Steadman
   // Bert van Dijk, 20050907
   var chill = 0;
   if (speed == "") {
      alert("U heeft de windsnelheid niet ingevuld") }
   else; {
      if (temp == "") {
        alert("U heeft de temperatuur niet ingevuld") }
      else {
        temp = checkDecimal(temp);
        speed = checkDecimal(speed);
        // Formule volgens Steadman:
        //chill = 1.41 - (1.162 * speed) + (0.980 * temp) + (0.0124 * speed * speed) + (0.0185 * speed * temp);
        // volgens A.Court:
        // chill = 33 + (temp - 33) * (0.550 + (0.417 * Math.sqrt(speed)) - (0.0454 * speed));
        // volgens Siple en Passel:
        // chill = 33 - (((12.12 + (11.6 * Math.sqrt(speed)) - (1.16 * speed)) * (33 - temp)) / 25.57);
        // de Canadese methode:
        // chill = 13.12 + (0.6215 * temp) + (0.3965 * (temp - 28.679) * Math.pow(speed, 0.16));
        // volgens JAG/TI
            speed = speed * 3.6;
            chill = 13.12 + (0.6215 * temp) - (11.37 * Math.pow(speed, 0.16)) + (0.3965 * temp * Math.pow(speed, 0.16));
            if (speed < 1.8 || chill > temp) chill = temp;
        chill = Math.round(chill * 10) / 10;
        return chill;
how do I start with this?
Edited by krommetje - October 18 2009 at 06:32
jbbtex
Posted: October 18 2009 at 20:19 | IP Logged Quote jbbtex
This is what I use - temperature in Fahrenheit, windspeed in mph:
ph_setvar_a(1,8,35.74 + (.6215 * {CURTEMP}) - (35.75 * ({CURWINDSPEED} ^ .16)) + (.4275 * ({CURTEMP} * ({CURWINDSPEED} ^ .16))))
This sets LOCAL8 to the result of the formula. CURTEMP and CURWINDSPEED are global variables. CURTEMP comes from a sensor in my backyard and CURWINDSPEED comes from Weatherunderground.
I got the formula here. http://www.usatoday.com/weather/resources/basics/windchill/w ind-chill-formulas.htm
Brady
krommetje
Posted: October 25 2009 at 09:54 | IP Logged Quote krommetje
Got it and entered it into my own macro....
now i have all the values I need....
thanx
