traviskleckner Senior Member
Posted: December 20 2007 at 10:39 | IP Logged
Hello,
I'm trying to create a trigger to turn a group of lights on/off with a double-tap on a switch (SwitchLinc). I've created macros to turn the lights on and off, and those work fine.
What I am having a hard time getting to work is the actual trigger part. I tried "Insteon Direct In" and that doesn't seem to work. I tried "Insteon Group In" and that works, but it seems to delay by 5 or more seconds.
Can someone help me on what I need to setup?
Thanks in advance.
Posted: December 20 2007 at 19:26 | IP Logged
Try Insteon Device Change.
Posted: December 21 2007 at 08:43 | IP Logged
Okay, thanks. That works. I still get a really long delay and I can watch the macro running through the steps. Is that normal?
Should I make a group and turn the group on and off?
Edited by traviskleckner - December 21 2007 at 08:44
