bhlonewolf Senior Member
![Senior Member](forum_images/3_star_rating.gif)
Posted: May 04 2008 at 22:17 | IP Logged
I don't know how it is that I've used PH for a solid year now w/o knowing this ...
I decided it would make sense to consolidate logic into my own Formulas so I'm not duplicating some logic in various macros. The thing is, how can I use my own formulas (that I've added to the formulas section) in macros? Every time I try using them they have errors.
Brian
Posted: May 05 2008 at 13:23 | IP Logged
OK, I think I kind-of figured out part of this.
I used the ph_formulabtn to run a formula. But what I'm really hoping to do is have that formula return a value. For example, I have a formula called IS_SUN_UP (yeah, simple) that is just:
if ( ph_seconds(now()) > [SUNRISE] AND
ph_seconds(n ow()) < [SUNSET] , 1, 0)
So running the formula should give me a 1 or 0 / true or false type of thing.
I can't seem to get the output of this formula in a macro. I have a few more complex ideas for formulas but figured I'd start here. I know I can get the output of a macro, but logically speaking, seems like formulas are more correct for this kind of thing... thoughts?
![Moderator Group](forum_images/5_star_rating.gif)
![Avatar](http://home.earthlink.net/~tonyno/tony-icon.gif)
Posted: May 05 2008 at 17:54 | IP Logged
I think what you want is to be able to create your own formulas, but I'm not sure it's possible.
What may get you close is a Submacro. Create your formula in a macro and then call it from other places with the Submacro command.
![Super User](forum_images/4_star_rating.gif)
![Avatar](avatars/seahorse_animation.gif)
Posted: May 05 2008 at 19:22 | IP Logged
The only thought I had was to stick the results in a variable then test that variable. Kind of a double whammy.
Posted: May 05 2008 at 21:26 | IP Logged
hmmm... can't create formulas? I thought that was the point of the formulas under formula explorer. (?)
I thought of a submacro too, but the functionality isn't a macro, it's a formula :) I know I'm splitting hairs but when I think Macro, I think "execute a series of commands" and when I think Formula, I think, "evaluate some conditions and return a result" ...
So the ultimate idea for me was to separate conditions into formulas, and then the macros would have just the basic execution steps...
Posted: May 05 2008 at 21:46 | IP Logged
So if I understand this correctly you want to, within a macro, call a formula with conditions and have the results passed back to the macro.
Posted: May 05 2008 at 22:17 | IP Logged
Yup that's right -- so consider the formula above called "IS_SUN_UP" -- from a Macro, I want to determine if the sun is up and do different things. So I'd like something like:
JUMP if([IS_SUN_UP]=1, 1, 999)
Obviously the Sun Up formula is pretty easy to just cut and paste but others may be a bit more complicated, so it would be great to get them into my own "custom" formulas.
Posted: May 05 2008 at 22:34 | IP Logged
Hopefully Dave is listening… I’ll look into it tomorrow.
Posted: May 05 2008 at 22:52 | IP Logged
You want to create a function with formulas. That's what I thought the Formulas table was for, too.
Edited by TonyNo - May 05 2008 at 22:53
Posted: May 05 2008 at 23:00 | IP Logged
AH ... so what do I do then? :)
Posted: May 06 2008 at 07:45 | IP Logged
We wait for Dave's wisdom!
Posted: May 06 2008 at 08:52 | IP Logged
In my testing the only way I can seem to pass parameters to and return codes back is using Variables. Maybe Dave has an easier way.
Posted: May 06 2008 at 10:42 | IP Logged
Cool -- ok that makes sense. Actually, in my case, I don't need to pass parameters into -- just get a return value. Maybe if the value of a global variable could be a formula ... hmmm...
Posted: May 06 2008 at 10:58 | IP Logged
Now that’s intriguing..
Posted: May 06 2008 at 13:23 | IP Logged
Sure! You could use ph_formula to evaluate it!
Posted: May 06 2008 at 15:31 | IP Logged
Tony -- back up a sec -- could you explain that a bit? 'Cause everything I've tried so far hasn't worked. Thx!
Posted: May 06 2008 at 15:50 | IP Logged
Me too.. I need an example cause I can’t make the thing work.
![Admin Group](forum_images/5_star_rating.gif)
![Avatar](http://power-home.com/images/phavatar.jpg)
Posted: May 06 2008 at 16:34 | IP Logged
Dohhhh!!! I knew I was forgetting something when I created the formulas table. Pete is exactly right. I need to have a formula function that returns the result of the formula.
The next alpha will have ph_formulabtn_s,ph_formulabtn_n,ph_formulabtn_d,ph_formulabt n_dt, and ph_formulabtn_t. These functions work just like the ph_formulabtn except that it will return the result of the formula (it also does not do any sendkeys whether checked or not).
I don't know how I missed this for so long (it was always the intent).
I think what Tony was alluding to was to place the formula in a global variable in the GV table. Then you could just use it directly use it in a macro with variable substitution.
Posted: May 06 2008 at 19:32 | IP Logged
Thanks Dave! Sounds good. Now I'll have to upgrade when the next alpha comes out :)
Posted: May 06 2008 at 19:55 | IP Logged
This is what I was thinking...
Set Global IS_SUN_UP if( ph_seconds(now()) > [SUNRISE] AND ph_seconds(now()) < [SUNSET] , 1, 0)
JUMP if( ph_formula( "{IS_SUN_UP}")=1, 1, 999) |
