MAWilsonPE Newbie
Posted: May 30 2008 at 19:21 | IP Logged
New PH user on trial version...
I got the TTS to work, getting weather with geturl, but having trouble sending a text message to my cell.
I have an e-mail account with Carolina RR and my cell service is AT&T. Does this look right?
ph_sendsmtpemail("smtp-server.nc.rr.com",25,"mawilsonpe@caro lina.rr.com,mawilsonpe,password","704xxxxxxx@txt.att.net","T est Message","This is a test of the PH sendsmptemail.")
ie: sendsmtpemail("e-mail sender smtp",25,"sender email address,user,password","cell phone email address","subject","text message")
Thanks, Mike
Edited by MAWilsonPE - May 30 2008 at 19:23
Posted: May 30 2008 at 22:23 | IP Logged
Welcome aboard!
Looks to be right. Not working?
MAWilsonPE Newbie
Posted: May 31 2008 at 08:38 | IP Logged
No, I am not receiving a message on my phone. Not sure if my problem is in PH, RR or ATT. I can send a message directly from RR and receive it. How can I be sure PH is executing the way I want it to? Can I tell if a msg was sent?
Is their anyway to watch the variable values as a macro runs? The "debug" doesn't catch much, it seems all the local and temp variables clear at the end of any macro an the debug log is nearly empty.
MAWilsonPE Newbie
Posted: May 31 2008 at 08:53 | IP Logged
Should I get a copy of my message in the "Sent" box of my RR e-mail? I do not.
Posted: May 31 2008 at 10:44 | IP Logged
Try entering that command in the web Formula page so you can see the error number.
Are you sure the port is 25? Lots of providers are using different ports.
I'm trying it here and seeing an error 4. Not sure what that is, but I'll figure it out.
Posted: May 31 2008 at 10:50 | IP Logged
The only way to know if the message was sent is to get a 0 result code from that formula.
You can also put it into the PH Multieditor to see the result.
I don't believe it will show up in your sent items.
jbbtex Senior Member
Posted: May 31 2008 at 20:22 | IP Logged
Try it without the user, password. I have RR here and send emails from PH without authentication.
__________________ Brady
MAWilsonPE Newbie
Posted: May 31 2008 at 20:33 | IP Logged
Great! With username and password I got a "4" as a result on the web Formula page. I took out the username and password and now it works! I get a "0" as the result in the web Formula page and I get the text message on my phone. It even works from a macro...
Thanks for your help!
Mike
Posted: June 01 2008 at 10:21 | IP Logged
I never would have tried that. Since I just did, it works!
