Subject Topic: Startup Script Post ReplyPost New Topic
RichardL
Posted: April 15 2009 at 12:05 | IP Logged Quote RichardL
Is there a "startup script" in Powerhome?
I want to define certain global variables upon PH startup.
If there is no startup script, how else can I be positive a global variable is defined with a specific value each time PH starts?
Thank you,
Richard
Back to Top View RichardL's Profile Search for other posts by RichardL
nadler
Posted: April 15 2009 at 12:17 | IP Logged Quote nadler
Define a Trigger as Trigger Type 'System Process' and
Trigger Id as 'Startup'. Every time PH is started
whatever Action and Action Type you define will be run.
It can be a macro, formula, raw formula etc.
If you need more detailed info just ask.
Noel
RichardL
Posted: April 15 2009 at 12:52 | IP Logged Quote RichardL
Beautiful!
I set it up and it is perfect! I also noticed the ability to execute at "reinitialize" and "shutdown".
The Reinitialize and Startup are both in place and identical.
Now that I have the variable dependable, I am continuing testing/tweaking my latest KeyPadLinc dependency issue.
You may see that on another post real soon!
Thank you!
Richard
