Lenny Senior Member
Posted: May 23 2010 at 11:40 | IP Logged
Maybe I'm not going around this the best way. I want to process code IF and only IF 2 GlobalVariables are TRUE.
So IF MODE=VACATION and OHDSTATUS=OPEN perform action.
I'm putting this in a single entry in my macro that updates keypad buttons for OHD Status since it's executed every time the state changes.
It seems to be ignoring the 1st IF anf processing it as true. Works fine with 1 IF.
/*VACATION MODE OVERHEAD DOOR ALARM*/
if("{MODE}" = "VACATION",if("{OHDSTATUS}" = "OPEN",ph_sendsmtpemail ("My.smtp-server.com", 25, "FROMeMail", "TOeMail", "OVERHEAD DOOR OPEN!", "VACATION MODE ACTIVE - OVERHEAD DOOR OPEN!"),0),0)
sjvonstein Groupie
Posted: May 23 2010 at 12:20 | IP Logged
Your ordering of the if statements appears to be correct. Are you receiving any formula syntax errors?
sjvonstein Groupie
Posted: May 23 2010 at 12:32 | IP Logged
*Deleted* See better suggestion below.
Edited by sjvonstein - May 23 2010 at 15:44
jbbtex Senior Member
Posted: May 23 2010 at 14:54 | IP Logged
So you want one action if both statements are true and
another action if either are false? Then try this way.
if("{MODE}" = "VACATION" AND "{OHDSTATUS}" =
edit: removed extra ',0)'
Edited by jbbtex - May 23 2010 at 21:12
__________________ Brady
Lenny Senior Member
Posted: May 23 2010 at 19:16 | IP Logged
MODE ACTIVE - OVERHEAD DOOR OPEN!"),0),0) |
Doh, now I feel dumb :) I was thinking If/If or If/Then... Changing to single IF with AND operator and removing the last ,0 it works as it should.
Thanks so much
Edited by Lenny - May 23 2010 at 19:18
