Subject Topic: Triggering from Virtual Device Post ReplyPost New Topic
Posted: October 12 2010 at 17:12 | IP Logged Quote GadgetGuy
I don't seem to be able to Trigger from the on/off actions of a Virtual Device. Not sure if it's what I'm doing or a PH limitation.
My Trigger is ...
and the PH Event Log shows the following after turnning off/on the Virtual Device...
But the Event Log shows no Trigger recognition (the associated Macro was not called) and actual events correlate to this )non-performance).
Am I missing something, or is PH?
Posted: October 12 2010 at 18:29 | IP Logged Quote grif091
I've not used Virtual Insteon devices but there is some mismatch with the posted information. The Trigger Type is "Insteon Group Out" (Group being key) but the Event Log shows an Insteon Direct command (Direct being key). A Group trigger does not fire from a Direct command.
Posted: October 12 2010 at 19:01 | IP Logged Quote GadgetGuy
Lee - Roger that, but I couldn't figure anything different to use. I initially tried the Insteon Group In action but that didn't work so then I tried the Group Out.
Is there anything I can use that will catch the virtual device's off/on commands?
Posted: October 12 2010 at 19:17 | IP Logged Quote grif091
The Trigger Type does not show Insteon Direct Out as an option?
Posted: October 12 2010 at 19:37 | IP Logged Quote grif091
I defined what I think/hope is a Virtual device (address V0.00.02). Used a ph_insteon("VIRTUAL DEVICE 1", 17, 255) which did fire a Trigger that is defined with Insteon Direct Out for "VIRTUAL DEVICE 1". The Trigger invoke a Macro correctly.
Posted: October 12 2010 at 19:39 | IP Logged Quote GadgetGuy
Lee - yes there is, and that was the answer!
You da man! Thanks
Edited by GadgetGuy - October 12 2010 at 19:41
Posted: October 12 2010 at 19:47 | IP Logged Quote GadgetGuy
PS- this was the final link in making a dual garage door open/close automation project a success.
I now have total control of my two doors with Keypad indication of open/close status.
At 9PM the doors now close if they were left open (saving me the grief of checking outside when our Michigan winters get down and dirty cold in Jan!)
I love PH. It is the Killer Ap EVER, as far as I'm concerned. I think I may now have one of the most automated homes in Michigan. Just about everything is under the control of PH.
My poor wife is growing ever more terrified, that if I die before she does that she will not have a clue how to make the house work.
But that should be no problem. I'm planning to stick around until at least 100! I'm having too much fun to leave any earlier.
