Subject Topic: ocelot varibles Post ReplyPost New Topic
slemm
Posted: December 19 2010 at 11:52 | IP Logged Quote slemm
Hello everyone
I just started working with PH.
How do you get the varibles from the ocelot controler
into the PH control center?
By the way i like this PH software very complex.
Lots of hours in front of the computer.
Back to Top View slemm's Profile Search for other posts by slemm
Posted: December 21 2010 at 21:37 | IP Logged Quote dhoward
Slemm,
Use the ph_getothervar function to read the Ocelot variables. You would need to setup a timed event or some other mechanism to read the variable as often as yo require. To get it into the Control Center, the easiest way would be to copy the Ocelot var (after reading it with ph_getothervar) into a Global variable that you've placed on the CC.
