Mitch Groupie
Online Status: Offline Posts: 43
| Posted: December 26 2010 at 16:08 | IP Logged
Ok, so this is maybe a little stupid of me, but I'm having trouble figuring out how to easily evaluate and debug macros. It would be nice if I could see results of a macro execution. In this case I am trying to capture strings from a serial port using ph_recvstring(1,32). It runs with no error, but I would like to display what it received so I can write case or if statements based on the contents. I've searched the forum and wiki but have not found an explanation on how to evaluate macro execution.
Thanks for your help.
Mitch
| Posted: December 26 2010 at 19:38 | IP Logged
You could add User Messages that include variable contents after critical macro lines. These will show up in the log.
Example:
User Message | "Backup failed with code " + [LOCAL1]
mertfg Newbie
| Posted: February 03 2011 at 04:19 | IP Logged
Hey, I also have been searching for this for quite a while now. I have been trying to write the conditional statements. I am so happy that I stumbled upon this now. Now I will try the solution given here. I will add the user messages at the end after the macro. If I get any errors regarding this, I will get back here. Anyway I would like to thank you for the help provided here.
__________________ magnetic messenger
