Subject Topic: Macro Conversion Post ReplyPost New Topic
Posted: November 13 2004 at 18:34 | IP Logged Quote TonyNo
Dave, I just started working on an app to translate an exported macro into more of a form that resembles what you see in PH, but, then had a thought. Is this something that would be trivial for you to do? Just wondering so I don't go off spending a bunch of unnecessary time.
Posted: November 15 2004 at 09:46 | IP Logged Quote dhoward
Hmmm...Interpreting the exported macro would be kind of a pain (especially if you're trying to work with SQL code). You can have your choice of export formats (CSV would be easier than SQL) by using SQL report (select * from macrodetail where id = 'ID') and then going to File->Export.
Are you looking for a printable report type of format detailing a macro? If so, then that would be pretty easy.
Let me know a little more what you had in mind and I'll look into it. Depending upon what you want, it may be fairly trivial and just something that I add to the reports menu.
Posted: November 15 2004 at 19:07 | IP Logged Quote TonyNo
The exported CSV idea is a good start.
For example:
insert into macroheader values ('BYE EXPIRE','BYE TIMER EXPIRE',0,0,1);
insert into macrodetail values ('BYE EXPIRE',1,9,'',NULL,'"Shutting down"',0);
insert into macrodetail values ('BYE EXPIRE',2,10,'BYE FLAG',NULL,'1',0);
insert into macrodetail values ('BYE EXPIRE',3,12,'C',2,'',0);
insert into macrodetail values ('BYE EXPIRE',4,12,'C',3,'',0);
insert into macrodetail values ('BYE EXPIRE',5,12,'C',4,'',0);
insert into macrodetail values ('BYE EXPIRE',6,12,'C',7,'',0);
insert into macrodetail values ('BYE EXPIRE',7,12,'C',103,'',0);
insert into macrodetail values ('BYE EXPIRE',8,12,'B',2,'',0);
insert into macrodetail values ('BYE EXPIRE',9,12,'B',3,'',0);
insert into macrodetail values ('BYE EXPIRE',10,12,'B',4,'',0);
insert into macrodetail values ('BYE EXPIRE',11,12,'B',7,'',0);
insert into macrodetail values ('BYE EXPIRE',12,12,'B',103,'',0);
insert into macrodetail values ('BYE EXPIRE',13,16,'',NULL,'if( {INTERNET FLAG} = 0, 999, 1)',0);
insert into macrodetail values ('BYE EXPIRE',14,1,'SETUP EMAIL-CELL',0,'',0);
insert into macrodetail values ('BYE EXPIRE',15,20,'',NULL,'" House now shut down! " /plus/ "{IP}"',0);
insert into macrodetail values ('BYE EXPIRE',16,1,'SELECT PORCH CAM',1,'',0);
Would look like this...
10 TTS "Shutting down"
20 Set Global BYE FLAG = 1
30 X-10 1 C2
40 X-10 1 C3
50 X-10 1 C4
60 X-10 1 C7
70 X-10 1 C Off
80 X-10 1 B2
90 X-10 1 B3
100 X-10 1 B4
110 X-10 1 B7
120 X-10 1 B Off
130 Jump if( {INTERNET FLAG} = 0, 999, 1)
140 Macro SETUP EMAIL-CELL
150 TTS " House now shut down! " /plus/ "{IP}"
160 Macro SELECT PORCH CAM
Posted: November 15 2004 at 19:29 | IP Logged Quote dhoward
Are you wanting the final result to be printable, or cut and pasteable?
Also, would this be something that would be generated within PowerHome directly from an existing macro or would this need to interpret the raw SQL insert statements?
Posted: November 15 2004 at 20:16 | IP Logged Quote TonyNo
Either printable or cut/paste would be fine.
Being able to do this within PH would be perfect. My thought is for a human-readable macro format for swapping, etc.
Posted: November 17 2004 at 10:35 | IP Logged Quote dhoward
Ok, that helps. I'll see what I can come up with.
Posted: November 18 2004 at 18:27 | IP Logged Quote TonyNo
Tanx!
