guerrand Senior Member
Posted: July 08 2006 at 23:11 | IP Logged
I'm not sure what could be the problem. I've checked over every thing that I could think of.
For some reason my Triggers won't Trigger. I verified that the formulas are valid but nothing happens when I init the trigger.
I watch the status and see the trigger x10 signal comming in but nothing happens. I hope I won't have to do a reinstall.
Thoughts guys?
__________________ VuMe
Posted: July 09 2006 at 22:36 | IP Logged
I'm officially confused. I reinstalled and the trigger still won't go...
Posted: July 10 2006 at 22:24 | IP Logged
Please post your trigger. Add as much detail as you can and maybe we can give you some useful feedback.
Folks are helpful here....we just need details and specifics.
Posted: July 10 2006 at 23:06 | IP Logged
Ok, here's the nitty gritty.
Desc: NIGHTTV
Action Type: Formula
Action: ph_x10btn('tube',3,0) + ph_x10btn('fan',100,40) + ph_x10btn('window',2,0) + ph_x10btn('closet',2,0)
Action Style: Queued
Status: Active
Trigger Type: X-10 RF In
Trigger ID: M
Trigger ID Number: 9
Trigger Value: On
When I press M9 On it is registered in the status but trigger never goes off.
The system I have PowerHome on is a Windows 2k system with all updates installed.
I just reinstalled from a fresh copy off the site and applied the patch as well.
Umm... not sure what else I can add.
Posted: July 10 2006 at 23:40 | IP Logged
Guerrand,
Since your trigger type is "X-10 RF In", do you have either an MR26A or W800RF32A X10 RF receiver connected?
If not and you are relying upon either an RR501 or TM751 to transceiver module to receive the RF X10 and convert it to a powerline signal to be decoded by a CM11A or similar then you'll need to change the trigger type from "X-10 RF In" to "X-10 In".
Posted: July 11 2006 at 00:04 | IP Logged
Yes, I have a mr26a (can't believe I forgot to mention that part) and a firecracker for xt..........
*checks some stuff*
Damn. I found the problem, I don't know why I didn't think of this sooner. The settings for the MR26A were messed up. I checked the settings and everything was blank. So I removed the controller and added it again. Works properly now.
Posted: July 14 2006 at 16:22 | IP Logged
Excellent!
