Posted: December 20 2006 at 19:50 | IP Logged
In my search for better slider controls for my PH lighting web pages, I came across this page.
Here is the sample page. Use guest for both name and password. Here is the code.
This again uses the DIMAC macro, which I have documented elsewhere here on the forum.
guerrand Senior Member
Posted: July 08 2007 at 23:42 | IP Logged
Hey Tony, I tried this out and keep getting an error that "an error occurred while retrieving data from the X10DEVICES and X10TYPES tables" Not sure why I keep getting that. Ever come up for you?
__________________ VuMe
Posted: July 09 2007 at 07:15 | IP Logged
Looks like I forgot to mention that you need to update the device names to something that matches your system and that the psp code is set up for Insteon.
Could that be it?
Posted: July 09 2007 at 12:09 | IP Logged
I already modified the psp with my device names, removed the little bit that kept adding the "I" for insteon and switched out the insteon stat request with the x10 version of the command. It seems to get the status correctly, when I dim a light using a remote and update the page it shows the proper level. (though the slider doesn't match the number)
Powerhome is receiving "desk_spot 100" as the info sent to the DIMAC macro. (as stated by the usermessage output) I did have a little trouble getting that macro to load though I'm not 100% sure how to fix it. It gave me an error halfway through the sql, where it has the second macroheader entry.
By the way, I was bored last night so I started looking around your "Holly Manor" setup. Looks great!
Posted: July 09 2007 at 12:34 | IP Logged
Ah! Unless you caught this already, you'll also need to change...
ph_getinsteonlevel("DeviceID")/255*100
to
ph_getx10level("DeviceID"))
For use with X10.
Quote:
I was bored last night so I started looking around your "Holly Manor" setup. |
Wow. I just looked at what you likely saw. That's old! Look here and use guest/guest for access...
Current Screens
Edited by TonyNo - July 09 2007 at 12:38
Posted: July 09 2007 at 15:27 | IP Logged
Yea, I already made that change. Something tells me at this point that maybe the problem lies in my DIMAC macro, maybe it's messed up somehow. do you think you could up a screenshot of it on yours so I can double check it?
That is what I saw, I started out on the old stuff but eventually linked my way through to that.
Posted: July 09 2007 at 17:49 | IP Logged
Sure. I'll do it tonight.
Ah, ok!
Posted: July 09 2007 at 19:05 | IP Logged
This was easier than a screen grab...
DIMAC Macro
Posted: July 11 2007 at 16:22 | IP Logged
Well, I confirmed that what I have is what it should be based on yours.
If I'm not mistaken, in looking over the logic of the macro it seems to be designed to handle the old style of powerhome unit addressing (a3 d1 etc.).
I got it working by changing line 50 to use [TEMP1] instead of [TEMP3][TEMP4] and removing lines 30 and 40. That seems to be all that is needed for it to work with the new device ID addressing system in use now. :D
You might want to do an update to the DIMAC macro post.
Posted: July 11 2007 at 17:59 | IP Logged
My post was exactly what I'm running right now.
For Insteon, I just use "id" and "" (nul).
martlist Newbie
Posted: July 18 2007 at 01:28 | IP Logged
I used the sample psp as is in my web folder and in both firefox and ie I am seeing no sliders. Just two text boxes with 0 in each.
Have you ever seen anything like this?
I did modify it to match my device names but still no sliders
Martin
Posted: July 18 2007 at 07:19 | IP Logged
Try the link to my sample page in the first post and let me know if you see the sliders.
Posted: July 18 2007 at 13:42 | IP Logged
Martlist, you'll need to download the js and css from the "this" link in tonys first post up there. I did the same thing and then looked at that page and thought durr. lol
Edited by guerrand - July 18 2007 at 13:57
martlist Newbie
Posted: July 18 2007 at 23:54 | IP Logged
Duh. Of course. Just downloaded it from here:
http://carpe.ambiprospect.com/
and I now see the sliders. Now I have to work out why it is not sending me back to sliderdemo2.psp but instead to execsendkeys.
The result is that the slider shows my last setting and not the current setting.
Posted: July 19 2007 at 07:34 | IP Logged
Maybe this does it.
Look for this line in the psp...
<input type="hidden" name="nexturl" value="/sliderdemo2.psp"> |
...and change the value to the name of your psp file.
roussell Newbie
Posted: November 02 2007 at 08:54 | IP Logged
I just ran across this web slider control and it looks pretty slick:
http://www.frequency-decoder.com/2007/09/10/unobtrusive-slid er-control-revisited
Here is the demo Page:
http://www.frequency-decoder.com/demo/slider-revisited/
Terry
Posted: November 02 2007 at 13:39 | IP Logged
Nice find.
ginigma Senior Member
Posted: March 13 2008 at 14:55 | IP Logged
Has anyone used the Tigra Slider Control on a PSP page, controlling Insteon devices?
http://www.scripts.com/viewscript/tigra-slider-control/23799 /
Edited by ginigma - March 13 2008 at 15:00
