PowerHome and Elk
 PowerHome Messageboard : PowerHome and Elk
Subject Topic: Elk and Powerhome Post ReplyPost New Topic
deckhardt
Posted: August 29 2007 at 02:41 | IP Logged Quote deckhardt
Is no one using the Elk with Powerhome?
Back to Top View deckhardt's Profile Search for other posts by deckhardt
sharby
Posted: August 31 2007 at 01:17 | IP Logged Quote sharby
Me Me Me. I'm running most of my rules and functionality through PowerHome. Let me know what you'd like to do. I'll start posting formulas that run much smoother then RP. Also, I freed up 50% memory for vital funtions within ELK.
-=*Sharby*=-
Back to Top View sharby's Profile Search for other posts by sharby
Posted: August 31 2007 at 09:07 | IP Logged Quote smarty
I will be in time. The new home construction is now on it's 11th month and is still not yet done (another 2 months maybe).
Prior to taking my system offline, I had PH and Elk "sort of" working togther, but that was before the latest PH version that supported the Elk much better.
I sure can't wait to get it back online. I too would like to see more posts in this section to help optimize PH/Elk integration.
Steve
deckhardt
Posted: August 31 2007 at 22:18 | IP Logged Quote deckhardt
Good to know, I have lots to learn, and it would be great if you could post formula's and examples the demonstrate how the two work together.
Dave
sharby
Posted: September 02 2007 at 02:26 | IP Logged Quote sharby
Once the ELK controller is configured and working, you can set up your Analog I/O with your hardwired and wireless zones. If you have Zone 4 wired up and working on ELK, try this in the Analog I/O section:
ID Descrip      I/O  &n bsp;    Controller Unit Point Loc Message
4   LV Motion   Elk Input ELK-INTERFACE 1 4 Living rm Motion
I named my ELK Controller (under setup/controller) ELK-INTERFACE.
Now on device status, you can view the entire house status and see the changes in real time.
-=*Sharby*=-
jack1747
Posted: October 05 2007 at 18:15 | IP Logged Quote jack1747
ID   Descrip     &nb sp;I/O  &n bsp;    Controller Unit Point Loc Message
-=*Sharby*=-
I must be getting tired... Can you explain this to me?...... And, How do I get the zones from the elk into PH? I want to be able to control events with the changes of zones. Thanks
Back to Top View jack1747's Profile Search for other posts by jack1747
sharby
Posted: October 07 2007 at 01:14 | IP Logged Quote sharby
the 1 4    constitutes that point code 4 on the main board (1) is Hardwire Zone 4. Check out the help section under powerhome for a better understanding of point codes.
Dave is writing an officially "How-TO" so that we all can understand the way ELK and PH speak to each other.
-=*Sharby*=-
EricM
Posted: October 22 2007 at 19:16 | IP Logged Quote EricM
i'd like to use powerhome to configure my insteon 2414S controller and then populate that configuration into my ELK. from what i'd read elsewhere, powerhome makes this process easy. is that true? are there directions on how to do this anywhere?
thanks in advance.
i haven't determined yet if i want to keep a pc running all the time vs programming everything in the ELK.
eric
Edited by EricM - October 22 2007 at 19:25
Back to Top View EricM's Profile Search for other posts by EricM
jimspobox
Posted: November 18 2007 at 20:27 | IP Logged Quote jimspobox
I'm using PH for linking and transferring the Insteon address to the Elk. After that, the Elk is used for all other lighting and control. A lot of my lighting is controlled by motion detectors through the Elk to Insteon. There is some delay in this but it may be that I need to use Groups, which i am not sure how to do yet. Other than that, it works well.
Jim
Back to Top View jimspobox's Profile Search for other posts by jimspobox
