scottmi1 Groupie
Posted: January 06 2007 at 08:36 | IP Logged
I have a CM11A and a Powerlinc 2414S controller. I have unchecked all the X10 receive checkboxes in the settings window for the Powerlinc, but I continue to receive incoming X10 messages from the Powerlinc in the log. Is there something else I have to do to turn off the incoming X10 messages from the Powerlinc?
Mike..
Posted: January 06 2007 at 19:51 | IP Logged
I believe it only turns off processing of the commands. If that is true, I would love for it to not display either.
scottmi1 Groupie
Posted: January 07 2007 at 08:02 | IP Logged
Thanks Tony. I guess I'll just have to learn to live with a more cluttered log!
Mike..
Posted: January 08 2007 at 01:18 | IP Logged
Mike,
Tony is correct...unchecking only turns off PowerHome processing of the received X10 command. X10 commands are still logged.
You can turn off ALL X10 logging by unchecking the appropriate boxes in the logs section of the PowerHome Explorer under Setup.
