Subject Topic: A critical error has occurred Post ReplyPost New Topic
outside1
Posted: October 07 2002 at 21:59 | IP Logged Quote outside1
 When I try to use the “Connect” button is get an error message some thing like …
A critical error has occurred.
Error Number: 39
Error Message: Error accessing external object property portopen at line 25 in function f_controllerconnect of object uo_controller_cm17a.
Window: uo_controller_cm17a
Object: uo_controller_cm17a
Event: f_controllerconnect
Most things seam to still be in working ordered, but I am a newbe, and I have just started with the program. Is this a issue I should be concerned with or can I continue exploring the program? Or is there I fix for this issue?
Back to Top View outside1's Profile Search for other posts by outside1
Posted: October 08 2002 at 13:44 | IP Logged Quote dhoward
This message is the result of the port you specified in the X-10 setup not being available on your computer.  It's possible that the port is actually there but already open by another application.  What port did you choose for your CM17A?  Also, what controller number is the CM17A assigned to?  Did you assign the same port to another controller in either the X-10 or IR setup screens?  PowerHome does not support the passthrough ability of the CM17A and only allows one controller per port.
Let me know,
