bhlonewolf Senior Member
Posted: April 02 2007 at 16:23 | IP Logged
Hi all, I can't seem to figure this guy out. Part of it is interpreting the log (below), but moreso the theory as to why this doesn't work reliably.
First, the scenario is: KeypadLinc Btn #3 (08.48.C5) is linked to control an ApplianceLink (07.D3.5E). PLC is 07.FA.17. I have one of my SignalRFs on the same line that the ApplianceLink is on. The ApplianceLink controls a transformer for outdoor low voltage lights. These are in PLC group #1 so PH can turn on and off the lights.
The problem: Pressing the keypad btn 3 causes the LED to flash a few times, but eventually (5-10 seconds) the lights come on (group cleanup?).
The other buttons on the keypad work fine (immediate response) to their remote loads. I can't quite tell if the problem is with the ApplianceLinc or the KPL. It looks like the KPL is having problems, but yet, the other buttons control their targets just fine.
The log file is below (sorry for the length) ... two things happened - I turned on Group 1 from PH, then turned it off ...
Any suggestions? Thanks!
SDM:DM=active,1.01.88.235,4/2/2007 5:01:02 PM,responded,07.FA.17,2.13
ui:!sendinsteonraw=00 00 00 00 00 01 CF 11 00
si:00 00 00 00 00 01 CF 11 00
PLC:sendinsteonraw=True
uifinished:!sendinsteonraw=00 00 00 00 00 01 CF 11 00
ui:srir=00 00 00 07 D3 5E 45 11 01
uifinished:srir=00 00 00 07 D3 5E 45 11 01
PLC:eventraw=03
PLC:eventraw=03
si:07 FA 17 07 D3 5E 45 11 01
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=05
4/2/2007 5:01:27 PM:nakmsg
PLC:SRIR=05
ui:srir=00 00 00 08 48 C5 45 11 01
uifinished:srir=00 00 00 08 48 C5 45 11 01
si:07 FA 17 08 48 C5 45 11 01
PLC:eventraw=04
PLC:receiveinsteonraw=04 08 48 C5 07 FA 17 65 11 01
4/2/2007 5:01:30 PM:ackmsg=08.48.C5:ON at 0%
PLC:SRIR=send failed
ui:!sendinsteonraw=00 00 00 00 00 01 CF 13 00
si:00 00 00 00 00 01 CF 13 00
uifinished:!sendinsteonraw=00 00 00 00 00 01 CF 13 00
ui:srir=00 00 00 07 D3 5E 45 13 01
uifinished:srir=00 00 00 07 D3 5E 45 13 01
PLC:eventraw=03
PLC:eventraw=03
si:07 FA 17 07 D3 5E 45 13 01
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=04
PLC:receiveinsteonraw=04 07 D3 5E 07 FA 17 6B 13 01
4/2/2007 5:01:46 PM:ackmsg=07.D3.5E:OFF at OFF
PLC:eventraw=03
PLC:eventraw=03
ui:srir=00 00 00 08 48 C5 45 13 01
uifinished:srir=00 00 00 08 48 C5 45 13 01
si:07 FA 17 08 48 C5 45 13 01
PLC:eventraw=04
PLC:receiveinsteonraw=04 08 48 C5 07 FA 17 65 13 01
4/2/2007 5:01:50 PM:ackmsg=08.48.C5:OFF at OFF
ui:srq:srir=00 00 00 05 9C 84 0F 19 00
uifinished:srq:srir=00 00 00 05 9C 84 0F 19 00
si:07 FA 17 05 9C 84 0F 19 00
PLC:eventraw=03
PLC:eventraw=04
PLC:receiveinsteonraw=04 05 9C 84 07 FA 17 2B 33 00
4/2/2007 5:02:54 PM:ackmsg=05 9C 84 07 FA 17 2B 33 00
PLC:srq:SRIR=04,05 9C 84 07 FA 17 2B 33 00
PLC:eventraw=03
ui:srq:srir=00 00 00 08 48 C5 0F 19 00
uifinished:srq:srir=00 00 00 08 48 C5 0F 19 00
si:07 FA 17 08 48 C5 0F 19 00
PLC:eventraw=03
PLC:eventraw=04
PLC:receiveinsteonraw=04 08 48 C5 07 FA 17 2F 51 00
4/2/2007 5:03:55 PM:ackmsg=08 48 C5 07 FA 17 2F 51 00
PLC:srq:SRIR=04,08 48 C5 07 FA 17 2F 51 00
PLC:eventraw=03
