Subject Topic: Function Keys Post ReplyPost New Topic
RWCS
Posted: November 13 2002 at 08:34 | IP Logged Quote RWCS
Is it possible to execute a macro triggered by a keyboard function key press?  If so how would one go about this. . .
Bob
RWCS LLC
Back to Top View RWCS's Profile Search for other posts by RWCS Visit RWCS's Homepage
Posted: November 13 2002 at 09:58 | IP Logged Quote dhoward
Bob,
Absolutely!!!  You can have up to 48 hot key macros which will appear in your menu under Macros.  To set this up, open the PowerHome Explorer and go to the Macro Maintenance.  You'll see a column labeled "Menu Shortcut".  In the dropdown you can select what hotkey will trigger this macro.  The first 12 macros are triggered with the hotkey combination Ctrl-F1 through Ctrl-F12.  Once you've configured the hotkey, either Reinitialize or restart PowerHome and the hotkey will be active.
RWCS
Posted: November 13 2002 at 13:23 | IP Logged Quote RWCS
Thanks for your response. . . Is there some way (in Windows) to assign a Function Key to PH (is that the Windows Scripting Thing?)  The Function Key Thing only seems to work when PH is active.
Can other Windows programs trigger PH Macros?
RWCS LLC
Posted: November 13 2002 at 16:40 | IP Logged Quote dhoward
Bob,
Within just the standard Windows Operating System, I know of no way to assign a hotkey to a particular application.  Ive seen this kind of thing done with 3rd party applications such as the special keyboards where you can assign an application to a "special" key such as to bring up an MP3 player or Internet Explorer.  Once PowerHome is active, then the function hotkeys will work but I guess the trick you're looking for at the moment is to bring PowerHome active.
The WSH or Windows Script Host is just a way to get more programming flexibility out of PowerHome.  Instead of writing macros (or in addition to), you can create Windows scripts (in either vbscript or jscript) to perform PowerHome actions.
Yes, other Windows programs can trigger PH macros.  This is accomplished through either Windows messaging or the Socket server.  If you want the very easiest way to do this, then you can have a Windows application send a message to PowerHome and create a trigger for this message.  This trigger could then in turn launch a macro.  An example of this would be to execute the Windows API function SendMessage.  If you were using VB, you would first need to make a couple of external function declarations:
Declare Function FindWindowA Lib "user32" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Declare Function SendMessageA Lib "user32" (ByVal hwnd
As Long, ByVal wMsg As Long, ByVal wParam As Long, lParam As Any) As Long
You would then execute this function with this line:
SendMessageA(FindWindowA(0," PowerHome  "), 1024, somedata, somemoredata)
Im not a VB programmer so the above may not be "exactly" right but is close enough to get the idea.
You would then create a trigger in PowerHome with a Trigger Type of "WM_USER" and a Trigger ID of "Trigger 1".  This trigger could check the somedata and somemoredata fields and execute the appropriate macros or sendkeys.
