| Posted: November 17 2002 at 14:26 | IP Logged
Bob,
Reading through your messages, it appears that this might have been working at one time and has now stopped.  Is this the case or did it never work?  Also, what OS are you running?  If this has never worked, it's almost as if the Microsoft Winsock control was not properly installed.
I see from your second message that the Socket Server also has the problem.  The Socket Server is loaded before the webserver so it would not be a conflict between the two.
If neither the webserver or the socket server has ever worked, I would suspect that the Winsock control is not properly installed.  I would attempt uninstalling the PowerHome Runtime and reinstalling it.
Both the webserver and the socket server should be able to start even if no network is connected as the local machine can connect to itself.
Let me know.
