         jeffw_00 Super User
           | Posted: December 22 2008 at 21:03 | IP Logged
apparently Houselinc lets you read the firmware revision level of a module (for example, the motion sensor).  I'm sure PH won't be out-done here.  Does anyone know how to do this?
  Edited by jeffw_00 - December 22 2008 at 21:26
         jeffw_00 Super User
           | Posted: December 29 2008 at 10:05 | IP Logged
bump?
           | Posted: December 29 2008 at 11:28 | IP Logged
PowerHome displays the firmware level of most devices under the Devices tab.  Not sure PH can currently do that for the motion sensor because of the lack of Peek capability in the motion sensor.  I could be wrong about that as the firmware level may be available in the link device identification message.  If it does require an I2 sequence I don’t think PH does that currently.  Also would require a PLM as the Controller as I don’t think the PLC supports I2.
         jeffw_00 Super User
           | Posted: December 29 2008 at 12:01 | IP Logged
Don't mean to be dim - I don't see an appropriate column under Devices
           | Posted: December 29 2008 at 12:18 | IP Logged
Jeff, Insteon Explorer – Devices and scroll right window all the way right. Motion Sensor does not display firmware.
         jeffw_00 Super User
           | Posted: December 29 2008 at 12:29 | IP Logged
Ok - i get that it doesn't. but for the sake of argument.  I go to that window, scroll right, and my last 4 columns are ACK Count, NAK count, event 03 count and failed matches.  am i missing something?
           | Posted: December 29 2008 at 12:35 | IP Logged
It is the 7th column from the right (Firmware). Just to the right of Previous Exclude column.  What level of PH are you running?  It may be a PH2 addition.
  Edited by grif091 - December 29 2008 at 12:42
         jeffw_00 Super User
           | Posted: December 29 2008 at 12:36 | IP Logged
must be a 2.0 thing - thanks
           | Posted: December 29 2008 at 13:04 | IP Logged
Whops... I forgot, sorry about that.
