Posted: August 10 2003 at 22:27 | IP Logged
Manny,
I have never used any of the RF repeaters having done the MR26A antenna hack. It's really not that hard, but if you've never touched a soldering iron, I would practice a little bit first on some scrap circuit boards trying to solder a couple of wires similar to the MR26A hack.
You can also check out the WGLDesigns W800 and W800RF32 devices which are an improvement over the MR26A and are available with external antenna jacks. Both of these devices will be supported in the next release of PowerHome which should be available soon.
