Posted: April 13 2009 at 23:02 | IP Logged
All,
In the PowerHome Vista thread, I see that there were several requests regarding getting a SmartHome PowerLinc 1132U or 1132CU working with Vista. I spent some time today working this very issue and was absolutely unable to get it to work.
The install of PowerHome to Vista went pretty well. I deviated a little from the standard install by installing PowerHome to c:\powerhome rather than the standard c:\program files\powerhome. I did this because I was told it would help eliminate some of the virtualization issues associated with UAC. Anyways, the install went fine and PowerHome seemed to work without any problems. I did not need to run in XP compatibility mode or as an administrator and was able to leave UAC enabled. Through the course of my testing however, I enabled/disabled all of these options in an effort to get the 1132(C)U working. I was unsuccessful.
Has anybody gotten either the 1132U or 1132CU to work with PowerHome under Vista? If so, please let me know so I can document the required steps.
GSgeek Newbie
Posted: June 01 2009 at 15:43 | IP Logged
Hi Dave,
I was able to load the 1132CU drivers by loading Smarthome Manager following the instructions on this link.
http://www.smarthome.com/forum/post.asp?method=ReplyQuote&RE PLY_ID=21777&TOPIC_ID=948&FORUM_ID=17
(See the post from bobfwilliams)
Unfortunately, PowerHome won't talk to the 1132CU, but Smarthome will. Apparently, PH isn't binding to the 1132CU even though I have it set that way.
Additionally, I recall I was able to get PowerHome to work with the 1132CU by installing on XP first then upgrading the OS to Vista.
Greg
Posted: June 02 2009 at 23:19 | IP Logged
Greg,
Arghhh!! I just reformatted by Vista machine (I HATE Vista) and reloaded XP .
Are you saying that you WERE able to get the 1132CU to work on a Vista machine if the Vista was an upgrade from XP?
