         k2zs Senior Member
 Online Status: Offline Posts: 113
           | Posted: February 27 2010 at 10:34 | IP Logged
I would like to set up Remote CC and Remote DS on 2 Dell laptops. 1 running Vista Home Premium and 1 running Windows 7. Is there any issues running the clients on those platforms?
  __________________ Scott, K2ZS
 Home Automation Ideas
           | Posted: February 27 2010 at 10:40 | IP Logged
I run SS on both so I don’t think you should have a problem.
         k2zs Senior Member
           | Posted: February 27 2010 at 11:07 | IP Logged
OK Thanks....
 I'm doing this for someone else and have never really used Vista or Windows 7 so this may be a "learning experience" :)
           | Posted: February 27 2010 at 11:16 | IP Logged
Vista and 7 are very similar where as XP is a little more technical from a user standpoint IMO. I have PH on Vista and 7 and they talk to each other seamlessly. I previously had PH on XP and Vista without a problem. They are plenty of post on running Vista if you run into a snag.
