Subject Topic: Voice Recognition - Vista Post ReplyPost New Topic
Posted: March 20 2010 at 16:12 | IP Logged Quote smarty
Anyone have any luck getting VR to work in PH with Vista as the operating system?
I downloaded and ran the three .exe files for SAPI4 from the PH website....saw a previous post that said VR only worked with SAPI4. I am using SAPI5 for TTS.
After trying a few things, all I get is "Critical Errors"...any pointers are appreciated.
VR for my set-up is NOT critical...I am fooling with VR just because I bought a new mic. :)
Posted: March 21 2010 at 12:27 | IP Logged Quote BeachBum
If it was me I would E-Mail the error to Dave. Funny, it was just today that someone asked me if anyone was using VR with PH. Now I know at least one is trying.
kikabyte
Posted: May 18 2010 at 09:17 | IP Logged Quote kikabyte
I failed to get it working with Vista.
I have now gone back to XP to keep things simple.
PLEASE let me know if you work this out because it would really help me shifting back to XP... (Mainly because my 6gb of RAM is only allowed to run at 3.2gb by XP!!! GRRR!
Back to Top View kikabyte's Profile Search for other posts by kikabyte
sjvonstein
Posted: May 18 2010 at 15:57 | IP Logged Quote sjvonstein
I'm using it successfully in Windows 7. UAC definitely had to be off in order for it to work. Haven't had to adjust anything else. I don't run PH in any compatibility mode or as an administrator.
Back to Top View sjvonstein's Profile Search for other posts by sjvonstein
kikabyte
Posted: May 24 2010 at 07:07 | IP Logged Quote kikabyte
That is wonderfull news! Any problems with windows 7 yet? Or can i get it ordered?
sjvonstein
Posted: May 24 2010 at 15:03 | IP Logged Quote sjvonstein
I haven't had any problems running under Windows 7. There's a couple things to keep in mind when installing:
1) Install directly to the C drive, not Program Files.
2) UAC must be turned off.
Posted: May 24 2010 at 17:41 | IP Logged Quote BeachBum
I do take all the defaults which does go to program files. I also run in compatibility mode plus turn off UAC on both Win 7 and Vista.
