Subject Topic: RFID Access Control Software Post ReplyPost New Topic
Tal56
Posted: June 22 2010 at 14:45 | IP Logged Quote Tal56
Hi guys,
I'm not sure of Powerhome has a plugin for this or if I'm looking for something completely different, in which case maybe someone can suggest something.
I'm looking for Access control software for a windows PC, that basically opens a Electric Strike Lock when access is granted. I've found several hardware solutions for the electronics I need, but was hoping for some good software to manage the users. Something simple and free would be great, but I don't mind paying for something if it's what I need.
Thanks for the help guys.
Back to Top View Tal56's Profile Search for other posts by Tal56
reighnman
Posted: February 09 2011 at 06:28 | IP Logged Quote reighnman
I want to do this too anychance this is a possibility??
Back to Top View reighnman's Profile Search for other posts by reighnman
patrickm
Posted: February 10 2011 at 17:02 | IP Logged Quote patrickm
I am doing that with my Elk M1 and Powerhome. I am using the P-300 Farpointe readers and the small PSK-3 tags instead of the reader and huge tags that Elk provides.
Managing users from the keypad or the ElkRP software is straight forward. The reader wires up to the Elk keypad directly but if you want to control the status LED on the P-300 directly from the keypad output zone you need to convert the active high output to active low. I used a 2N3904 transistor but a small relay could be used.
Patrick
