rtt3821 Newbie
Posted: July 06 2010 at 21:03 | IP Logged
I have tried to install the downloaded 30 trial version of PowerHome but keep getting an error message that there are corrupt files, Is PowerHome compatible with Windows 7?
sjvonstein Groupie
Posted: July 07 2010 at 07:18 | IP Logged
It is compatible. Be sure you have administrator rights. Furthermore, disable UAC if you feel comfortable doing so, and then right-click on the installation file and click "Run as Administrator"
Posted: July 07 2010 at 08:24 | IP Logged
I run on both Win7 and Vista. Although it sounds like your download failed. I would download the file again then install taking the defaults. Then do what sjvonstein suggested. If you still have a problem post the details here.
rtt3821 Newbie
Posted: July 07 2010 at 14:19 | IP Logged
I re-downloaded the file and chose "run as administrator" and I still get the same error message,"The configuration data for this product is corrupt. Contact your support personnel".How do I correct this problem?
Posted: July 07 2010 at 14:39 | IP Logged
Doesn’t sound like a PowerHome problem. I would try running CCleaner and see if that fixes it. Do you also get an error number?
Posted: July 07 2010 at 15:44 | IP Logged
Here’s a little tidbit I found but don’t know if it pertains to you.
Here's what worked for me:
In the Registry Editor delete the entire
HKey_Current_User\Software\Microsoft\Installer key.
rtt3821 Newbie
Posted: July 07 2010 at 17:18 | IP Logged
Thanks for your responses. I don't get an error number. Will Deleting the registry key cause any problems?
Posted: July 07 2010 at 18:23 | IP Logged
You might want to backup the register just in-case but I don’t believe it would be a problem.
This is what mine looks like.
HKEY_CURRENT_USER\Software\Microsoft\Installer
HKEY_CURRENT_USER\Software\Microsoft\Installer\Assemblies
HKEY_CURRENT_USER\Software\Microsoft\Installer\Assemblies\C: |Program Files|Simplehomenet|SHN Utility Suite|Interop.SDM3Server.dll
HKEY_CURRENT_USER\Software\Microsoft\Installer\Assemblies\C: |Program Files|Simplehomenet|SHN Utility Suite|Simplehomenet Utility Suite.exe
HKEY_CURRENT_USER\Software\Microsoft\Installer\Features
HKEY_CURRENT_USER\Software\Microsoft\Installer\Features\5B99 6E3BEEE71BA47ABB4AB3B7D449DE
HKEY_CURRENT_USER\Software\Microsoft\Installer\Features\5C04 822FF182EA7469CCC26D7D176B41
HKEY_CURRENT_USER\Software\Microsoft\Installer\Features\6BBF DF96D153C8B4988D68D79C0D2A4A
HKEY_CURRENT_USER\Software\Microsoft\Installer\Features\CA53 85F66D1AE0F40A4A51E65895564E
HKEY_CURRENT_USER\Software\Microsoft\Installer\Products
HKEY_CURRENT_USER\Software\Microsoft\Installer\Products\5B99 6E3BEEE71BA47ABB4AB3B7D449DE
HKEY_CURRENT_USER\Software\Microsoft\Installer\Products\5C04 822FF182EA7469CCC26D7D176B41
HKEY_CURRENT_USER\Software\Microsoft\Installer\Products\6BBF DF96D153C8B4988D68D79C0D2A4A
HKEY_CURRENT_USER\Software\Microsoft\Installer\Products\CA53 85F66D1AE0F40A4A51E65895564E
HKEY_CURRENT_USER\Software\Microsoft\Installer\UpgradeCodes
HKEY_CURRENT_USER\Software\Microsoft\Installer\UpgradeCodes\ 3C7D85F192911FF4C809F64EF2802F45
HKEY_CURRENT_USER\Software\Microsoft\Installer\UpgradeCodes\ 7224ECCC6BF7B2A459BE93BD0A673F56
HKEY_CURRENT_USER\Software\Microsoft\Installer\UpgradeCodes\ BE094BE37F321114BB87A1746A498BC8
HKEY_CURRENT_USER\Software\Microsoft\Installer\UpgradeCodes\ FCADAC80A127C2447B673F04CC54F8B5
