kev21986 Senior Member
Online Status: Offline Posts: 199
| Posted: February 12 2011 at 12:22 | IP Logged
When I try to install the 2.1.2 beta on Windows 7 x64 I get an error message
saying "Can't start NTPort Library driver.". It tells me that that install failed
but PH seems to have been installed. Everything works except the Socket
Server and the Web Server. How can I fix this?
I have tried uninstalling, restarting and reinstalling but nothing seems to
change.
__________________ Kevin Smith
@respectTheCode
| Posted: February 12 2011 at 12:43 | IP Logged
This is the error I get in PH when I reinit after enabling the web server
A critical error occurred at 2011-02-12 12:43:11.177.
PowerHome Version: 2.1.4
Error Number: 39
Error Message: Error accessing external object property autoresolve at line
41 in constructor event of object uo_webserver.
Window: uo_webserver
Object: uo_webserver
Event: constructor
Line: 41
Edited by kev21986 - February 12 2011 at 12:45
@respectTheCode
| Posted: February 12 2011 at 12:45 | IP Logged
Oh and now it wont communicate with the PLM anymore. It was doing that
before though.
@respectTheCode
| Posted: February 12 2011 at 13:18 | IP Logged
Ok so I am making some progress. If I have 2.1b installed when I install
2.1.2 it doesn't give me an error on install, but 2.1.2 and 2.1.4 don't work.
Well Im stuck so I guess Im sticking with 2.1b for now.
The annoying thing is that 2.1.4 works on my old XP computer.
@respectTheCode
w4wn Newbie
| Posted: February 15 2011 at 20:23 | IP Logged
I get the same "Can't start NTPort Library driver." error when installing the 2.1.2 beta on two separate Windows 7 x64 machines here also...
| Posted: February 15 2011 at 20:34 | IP Logged
here also... |
I never figured out a way to make it work so I am back on 2.1b.
@respectTheCode
| Posted: February 15 2011 at 20:36 | IP Logged
For what it’s worth I’m on Win 7 Pro X64 without the problem. I took all the defaults and had to edit the INI to correct some stuff. I’m at 214. I also have it installed on XP and Win 7 32 bit. The 64 bit system nominally does not have any controllers active but has when testing.
w4wn Newbie
| Posted: February 15 2011 at 21:07 | IP Logged
So far my 2.1.4 installation seems to work OK despite the error msg. Copied my db & pwrhome.ini from WinXP machine, ran PHUPG.EXE, had to change the PLM com port in Settings and seems to be running OK. Saw a previous post mentioning that the NTPort Library driver is for a parallel port device - my machine has no parallel port, could that be the issue?
| Posted: February 16 2011 at 05:09 | IP Logged
The only real problem I had with 2.1.4 was that the web and socket servers
both didn't work.
@respectTheCode
ConPro Newbie
| Posted: January 15 2012 at 17:38 | IP Logged
Was there a solution for this? I am on Win 7 64 and web and socket do not work on either. I also get a errormessage on startup and have to manually connect the PLM and turn on timed events. Any help would be appreciated.
CRITICAL ERROR
Error Number 39
Window: uo_socketserver
object uo_socketserver
Event: Constructor
Line 11
Thanks Tom
ConPro Newbie
| Posted: January 15 2012 at 19:45 | IP Logged
To answer my own question, I turned of UAC and both problems went away. Now to figure out the right sequence to connect to the socket server.
Tom
| Posted: January 15 2012 at 23:08 | IP Logged
Should be no problem with Socket Server. Just make sure you address the right ports and you have it installed on both systems and is active.
ConPro Newbie
| Posted: January 15 2012 at 23:35 | IP Logged
I have the rudimentary layout and the class for the PH_SS is working, now to set up the DIO/AIO part of the software and I will be on my way to finishing the interface. (I am using 6 LabJack IO boards to monitor 100+ DIO and 15+ AIO ports and attach logic to each port.
This is the last piece to get my house back to full automation status. When done, you almost never touch a light switch, motion sensors and door sensors anticipate you and keep the way lights in front on, and turns them off behind you.
One caveat. My kids never learned to turn off lights and now as adults they are having trouble adjusting to their 'dumb' apartments ;)
| Posted: January 15 2012 at 23:39 | IP Logged
Got cha… The only lights that are manual in our house are the overheads in the bathrooms. Otherwise we are at the mercy of Dave….
ConPro Newbie
| Posted: January 16 2012 at 12:39 | IP Logged
Could be worse, at the mercy of HAL ;)
Tom
cox181 Newbie
| Posted: January 31 2012 at 16:24 | IP Logged
Why hasn't Dave addressed this issue yet? Or is there a fix
posted in a different forum section?
| Posted: January 31 2012 at 22:55 | IP Logged
Taylor,
Which part of the thread are you referring to (there were a couple of issues )? Are you having a problem with the NTPort driver not loading or the Web and Socket server not loading?
The NTPort driver is only used by the Generic Parallel port driver and the K8000 driver so would not cause an issue if it doesnt load (this should be fixed though in the next beta). If its the websever and socket server not loading, then you'll most likely need to turn UAC off.
Let me know,
