Subject Topic: Default Dimming Support in Control Center Post ReplyPost New Topic
GCollins
Posted: September 05 2011 at 23:55 | IP Logged Quote GCollins
I just downloaded the trial of PH 2.1b and have been experimenting with it all day. I'm using an Insteon 2413S PLM, and all of my lighting devices are operating in X10 mode. I'm a bit disappointed that the default Control Center generated by the wizard only has on/off controls, but not dim. Is this easily resolved?
Back to Top View GCollins's Profile Search for other posts by GCollins
Posted: September 19 2011 at 22:42 | IP Logged Quote dhoward
GCollins,
Adding dim and bright controls in the Control Center is fairly easy. Just right click the CC screen and select "Design" from the popup menu. You can then add new controls or copy/paste existing buttons and change their action to dim/bright.
This will allow to add standard dim/bright buttons but will not give you an easily accessible slider type control. This will be a new feature in an upcoming beta with the redesigned Control Center.
