| Posted: April 29 2004 at 15:25 | IP Logged
Tony brings up a good point about the power .
I use both hardwired and X-10 2.4ghz cameras. I also have an 802.11b wireless network (2.4ghz). You will get interference, but you can minimize it based upon the channels you select. I don't seem to notice interference on the network (it's packets), but I can "see" the interference the network causes the cameras. Ive been able to minimize the interference by setting the video receiver to channel "A" (out of ABCD) and setting my wireless network on channel 11 (out of 1 thru 11). If you were to look up the frequencies of each respective unit, you would find that these settings give the widest separation.
Another suggestion would be to use a black and white camera. The color cameras from X-10 don't work very well in low light situations which might be the case in the early morning hours. A B&W will typically have a much lower lux rating (the lower the better).
Since power might be an issue, you may want to look at one of those X-10 wired Nightwatch cameras. The power and video are all carried within a single (60 foot I believe) cable.
