Subject Topic: TTS Setup on Win7 64bit / Easy way to deb Post ReplyPost New Topic
pingmustard
Posted: September 01 2012 at 19:15 | IP Logged Quote pingmustard
Could someone help me with TTS setup?   I just tried installing both SAPI 4 (all 3 exe on setup cd) and SAPI 5 (1 exe).    Within PH Explorer -> Setup > TTS, I've set it as SAPI 5.
I tried to run in the multi editor but no sound comes out:
ph_tts("HELLO WORLD!")
Output:
Formula Evaluation
     Execution time: 0.001 seconds.
     The formula evaluates to: 0
I also notice the Voice > TTS Setup dialogue has a dropdown with blank. Is there something that should be in here?
I tried playing with TTS from windows control panel (Control Panel > Change Text to Speech Setting) and I was able to play with the Microsoft Anna voice on some sample text.
Also, is it possible to direct TTS or any audio playback to a specific device output? I believe the TTS to specific audio device was asked several years ago and it was mentioned it may be included in future PH.
I'm running:
PH 2.1.4
Windows 7 64 bit, using default c:\powerhome running as admin.
Edited by pingmustard - September 01 2012 at 19:17
Back to Top View pingmustard's Profile Search for other posts by pingmustard
