        | sifu128 Groupie
          Hey everyone, I have a problem and need some help. For the last 5 years my entire home has been using SwitchLinc 2476D 600 Watt dimmers. Recently one of them went bad and I had to change it. The 2476 were out of stock so I bought the upgraded replacement which is the 2477D (dual band).
           | Posted: May 27 2013 at 14:46 | IP Logged |   |
 I am able to auto configure it and Powerhome will find the device by device id. The problem that I am having is that I am unable to control the light with any commands to turn it on or off. I don't have any PLC=5's at all, just 3's and 4's. Every other device works.
 Does anyone have an idea what the problem could be?
 TIA
 Dave
        | Back to Top |     |
        | BeachBum Super User
          Try checking I2CS in DEVICE col. IEngine
           | Posted: May 27 2013 at 15:45 | IP Logged |   |
        | Back to Top |     |
        | sifu128 Groupie
          Nope, didnt work. Any other ideas?
           | Posted: May 27 2013 at 18:41 | IP Logged |   |
        | Back to Top |     |
        | BeachBum Super User
          Check links to PLM as controller and/or responder
           | Posted: May 27 2013 at 19:34 | IP Logged |   |
        | Back to Top |     |
        | sifu128 Groupie
          Those are all setup and nothing. I factor reset the switch and still nothing. No errors in the PCL log.
           | Posted: May 27 2013 at 19:37 | IP Logged |   |
        | Back to Top |     |
        | edtude Groupie
           | Posted: May 27 2013 at 20:19 | IP Logged |   |
| sifu128 wrote:
       | Those are all setup and nothing. I factor reset the switch and still nothing. No errors in the PCL log. |  |  |
 What are you using as your interface? A PLM or PLC? The PLC will not support the commands necessary for you new switch. I found this out the hard way myself.
        | Back to Top |     |
        | sifu128 Groupie
          I am using the 2414U which is the USB controller (PLC). What is the reason for it not to work? It broadcasts and is able to be picked in setup mode with no problems at all.
           | Posted: May 27 2013 at 20:52 | IP Logged |   |
        | Back to Top |     |
        | grif091 Super User
          SmartLabs/Smarthome has updated the Insteon protocol to I2CS.  Not important what that stands for as much as devices shipped after March 2012 are likely I2CS with every device being shipped now being I2CS.  These devices require Extended commands to manage the link database.  You need 2.1.4 + the I2CS Zip.
           | Posted: May 28 2013 at 01:13 | IP Logged |   |
 Also the old 2414 PLC does not support Extended commands.  Along with updating the PH2 software a PLM, either 2413S or 2413U will be needed.  These are the only PLM variants now being sold.
        | Back to Top |     |
        | sifu128 Groupie
          Lee! This is perfect and just what I was looking for. THANK YOU! I know my equipment is pretty dated but this helps a ton!! I will compare the prices between trying to find an older switch or just upgrading the PLM which seems to be the way to go so I can avoid this problem in the future.
           | Posted: May 28 2013 at 07:00 | IP Logged |   |
 Do you know where I can download the 2.1.4 + the I2CS Zip file?
        | Back to Top |     |
        | grif091 Super User
          Go to this link for 2.1.2.   It is many pages long but has a link to 2.1.4 (to be installed on top of 2.1.2).  There is also a link to the I2CS Zip file which is unzipped into 2.1.4.  The Zip file has only two files but these have the I2CS support.
           | Posted: May 28 2013 at 07:28 | IP Logged |   |
 http://www.power-home.com/forum/forum_posts.asp?TID=2723&PN= 1
 It may not be possible to obtain a non-I2CS device.  All the devices coming from Smarthome today have I2CS firmware including the 2476D when it is back in stock.
        | Back to Top |     |
        | sifu128 Groupie
          I am actually almost done with the upgrade. I just purchased the new PLM. All of the switches I have in the house are 2476D's, I was just unable to find one in stock anywhere so opted for the 2477D. I should be good right once I get the new PLM tomorrow?
           | Posted: May 28 2013 at 07:42 | IP Logged |   |
        | Back to Top |     |
        | edtude Groupie
          All of your old switches will work just fine with the new PLM. Once you get that you will be just fine.
           | Posted: May 28 2013 at 08:44 | IP Logged |   |
        | Back to Top |     |
        | sifu128 Groupie
           | Posted: May 28 2013 at 10:55 | IP Logged |   |
        | Back to Top |     |
