PhilC Newbie
Online Status: Offline Posts: 39
Posted: September 15 2004 at 04:29 | IP Logged
Hi,
Is it possible to have a mouse over event so that a button changes colour or image swaps when it is clicked?
Ideally, I would like to have my X10 House codes displayed as buttons (A1, A2, A3 etc) which you would select for an action, such as dimming or on/off. It would be nice if as you select the house code, the button changes colour to show it has been selected.
Many thanks
Phil
Posted: September 20 2004 at 18:34 | IP Logged
Phil,
PowerHome doesnt have any "mouseover" events but you can physically effect the appearance of the Control Center when buttons are pressed.
I would first use the beta version 1.03.4.1 since these functions changed significantly. You could then use Formula buttons that not only select the housecode but include a function to change the buttons color (ph_setccbtnbcolor). If you look in the function reference under "Control Center", you'll find a complete list of buttons that allow you to modify the Control Center's appearance.
Hope this helps and let me know if you need any help,
