        | patrickm Senior Member
          I just installed 2.15a with an Insteon hub and have noticed that the device status is not updating after ph_insteongroupcu commands.  If I close the device status window and reopen it the device status is correct.
           | Posted: October 09 2014 at 16:01 | IP Logged |   |
 Is there some new setting in 2.15a that I am not aware of?
 Patrick
        | Back to Top |     |
        | dhoward Admin Group
          Patrick,
           | Posted: October 10 2014 at 22:37 | IP Logged |   |
 I don't think this has been reported yet but Ive added it to the debug list. I'll look into the code shortly and let you know what I find out.
          I had an error message during PH reinit:
           | Posted: October 11 2014 at 15:53 | IP Logged |   |
 Unable to retrieve next internal link on Insteon PLM (SmartLinc) CNTL1.  Attempting to restart controller (1 of 5)...
        | Back to Top |     |
        | dhoward Admin Group
          Patrick,
           | Posted: October 20 2014 at 11:08 | IP Logged |   |
 Im addressing your issue above and cant see where the problem is. This was definitely an issue with PowerHome 2.1.5 but was fixed in 2.1.5a. Can you give me some more info on how the group cleanup command is being issued and details on the specific command, extended/standard, etc?
 Ive checked through the code and so far cannot locate where the problem lies so any additional info would be a huge help.
           | Posted: October 20 2014 at 12:16 | IP Logged |   |
 |  I am not doing anything unusual.
 ph_insteongroupcu("STEP_LIGHTS_DIM","STEP LIGHTS",ion)
 Patrick
        | Back to Top |     |
        | dhoward Admin Group
          Patrick,
           | Posted: October 20 2014 at 13:30 | IP Logged |   |
 In the Help|About window can you verify that the PH version is indeed 2.1.5a (sorry...have to ask
 With that out of the way, can you add a ph_devicerefreshstat() function immediately after the call to ph_insteongroupcu? If that corrects the problem, it will help me pinpoint where the issue is.
          It is 2.1.5a  Database 2.1.5
           | Posted: October 20 2014 at 14:04 | IP Logged |   |
 This works fine:
 ph_insteongroupcu("STEP_LIGHTS_DIM","STEP LIGHTS",ion) + ph_devicerefreshstat()
 Will that update Elk status as well?
 Patrick
        | Back to Top |     |
        | dhoward Admin Group
          Patrick,
           | Posted: October 20 2014 at 14:55 | IP Logged |   |
 The ph_devicerefreshstat function should "trigger" the update of all modified devices (who have had the lastchange time/date stamp updated). Since this works for your ph_insteongroupcu function, this tells me that Im properly updating both the status and the lastchange but must be missing the "trigger". Now Ive just got to find where Ive missed it.
 Another thing to help pinpoint the exact code...in your Insteon Explorer top section, do you have "Update on ACK" checked or unchecked?
 Also, are you having a problem with Elk devices updating? If so, give me some details and I'll see what I can find out.
          I do not have update on ACK checked.
           | Posted: October 20 2014 at 15:38 | IP Logged |   |
 With the ELK I frequently have one of the ELK areas not indicating the correct ARM status, ARM state and ALARM state in the device status window after arming both areas.  The status will update if I disarm and arm one of areas again.
 Patrick
        | Back to Top |     |
        | dhoward Admin Group
          Patrick,
           | Posted: October 20 2014 at 19:26 | IP Logged |   |
 Ive setup a test scenario in my system to try and duplicate and so far I cant get a failure. Ive unchecked "Update on ACK" (I usually run with it checked) and have group 3 of my PLM controlling a switchlinc. When I send a group cleanup command to this device, my device status screen updates without any issues.
 What PLM group number is the "STEPS LIGHT DIM" group and what kind of device is the "STEP LIGHTS" device? In the link for the STEP LIGHTS device, what is the "Button" number (Links tab, Button column) for this group number?
 Concerning the ELK...the ph_devicerefreshstat probably won't help you. If the ELK status doesnt update correctly when you close and reopen the Device Status window, then this function will have no effect. It sounds as if the communications between ELK and PowerHome may have an issue if the ELK status are not displaying properly. When the ELK controller is first connected to PowerHome, PH will query the Elk for the current status on all of its devices and updates internal tables to track this. After that, PH is just listening for commands from the ELK. When a command is received, the internal status and device status screens are updated to reflect the command. If the comms have an issue, the command may be missed and PowerHome will be out of sync until that device is updated again or the ELK controller is connected and reconnected within PowerHome. Do you know if you have any ELK comms lost messages in your eventlog?
           | Posted: October 21 2014 at 12:06 | IP Logged |   |
 |  The group numbers are 50 and 51.  The button number is 0.  The device is a 2476D Switchlinc 600W dimmer.
 I have seen in the past a dialog box that has popped up that indicated that PH lost communication with the ELK but there were no event log entries.  That occurred during a normal occupied condition not during arm or disarm events.
 Would it be possible to query the ELK event log via PH?  I would like the user info to be in sync as well.
 Patrick
        | Back to Top |     |
